993RS Steering Wheel on 964?
Is the 993RS Steering Wheel a direct fit for the 964? Apart from deactivating the airbag warning light? Suncoast Porsche's website says it is.
http://e-partssales.com/Merchant2/me...Code=POTE993IN
Thanks,
JF
Thanks,
JF
I have this in my car and it was a direct fit, simply unbolt the old one and bolt in new one. Was literally a 10 minute job. However my car did not have an airbag so I don't know if this complicates the issue at all.
Regards,
Neil
Regards,
Neil
I understood that the 964 and 993 wheels are not interchangeable. Make sure you get the correct wheel fitment for the 964, which should be available for this wheel.
Andy is right if memory serves, the splined hub is a different size, a couple of mm larger....the steering wheel however is in 964 fitment, as I have one fitted.
Kevin.
Kevin.
I was reading this write up on some mods that a fellow 964'er posted. It was informational on this subject.
http://www.porsche964.nl/my964/drivingpos.php
