It's quite simple. Remove the single screw on the bottom of the headlight trim ring. The rim should then pop right off. It's pretty straight forward from there.
Follow instructions as above. I didn't take the glass lense off but washed out with washing up liquid/detergent. Dried with a hair dryer and popped them back in.
Just make sure you connect up the elec adjustment hose.
