Plug on back of clock
Hi All, I am a new member to this forum although I have owned my 90 C2 for a couple of years. I was re-installing my clock after having it repaired. During the process the plug that goes to the back of the clock came apart into two pieces. The connectors that go to the pins on the clock came out of their places in the plug. Does anyone know where I can go to get a picture/diagram showing wire color and placement of those wires in the plug. I tried to put them back in the plug where I thought they belonged but the clock doesnt work and some of the warning lights that never came on before came on so I know I've got some of them in the wrong spot in the plug. Sorry for the long post, THANKS for any help.
Hi
Your best bet is to pick up this
http://cgi.ebay.co.uk/PORSCHE-964-WO...item1c17e56e03
It will have the wiring diagrams for everything you need along with most other information about bodywork, chassis, engine and gearbox. You can get the bentley manual but its a little vague on detail for what you need.
the inner and outer pcb's are hard wired with 3 steel bars. if you can pull them apart there is a possibility the tracks have torn or become damaged. I found this out the difficult way, pcb track rewiring and some soldering sorted.
http://www.porsche964.co.uk/technical/clock.htm
is also a reasonably helpful bit to tell you what light etc is where.....and to tell you how to fix the clock power pins if they are stuffed
This kind of sad but...what's a PM? I Thank you all for the input as it is really appreciated, but I need is a drawing of some kind that shows where in the plug the various colored wires go.
