Calling any Orlando Rennlister
Here are a few recommendations in order of importance, imho of course, from what I saw:
Remove engine tray and clean/degrease the engine
Replace all the oil lines we spoke about
A few threads to help:
Oil leak (and need PET help) UPDATE: Leak found added pictures
Page 10,11 of my thread
Here is a partial list of what you will need:
#21 - 964.207.241.04
#22 - 964.207.251.02
#26 - 964.207.217.00
#30 - 964.207.130.02
#46 - 964.207.254.07 (this is the one that was leaking badly)
#54 - 964.207.252.14 (this one just check after cleaning... no sense in spending the $$ if this one is fine)
Get the alu washer to replace them (some leaks are due to corroded aluminum washers)
N.013.813.2 (you will need 1)
900.123.139.30 (get at least 6)
Wrench set (PEL-TOL-P242) (believe me... nothing else works in that limited space...)
Also get two new rubber support for the oil tank (bonded rubber buffer):
#3 - 999.703.324.00 and 999.703.246.00
and get the proper clips for that side fin/sill... that spray on foam the PO used to hold it in place it is just not right...
Rubber strip: (#6) 964.559.295.01 for the shark fin
Clips: (#4) 999.507.373.00 (need 2)
and get a few plastic nuts (#15) 999.049.022.40 (get like 10 of these, you will use them in many places)
Also, check the battery connections. A couple of starts sounded like a tired starter. Could have been a week battery or poor cable connection. Charge the battery, clean the connections to the battery and at the starter end.
Bleed the brakes and clutch.
I hope that helps! Everything else you can take your time fixing.
Even with the few things you need to fix, that car was a great buy!
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
I know, I know I'm violating Rennlist etiquette. Was gonna take pics today, but still dirty from the drive up. Will take and post pics tomorrow when I get a chance to wash her. Here is a pic from my camera phone last night when I got in.
