About 50 hp short of perfect...
#32
#33
I think that a kit from vitesse racing, it would give you the wright bang for the buck if the saying is so. And please do an dyno before and after. So that al unbelievers see the difference.
But willing to spend more money on the car talk to geoffrey.
#37
Agent Orange
That's weird since every true Porsche guy that I know says no to A/C. So you better not be running one otherwise we'll have to rescind your "True Porsche Guy" membership and banish you from the ranks of this highly exclusive group. You won't be able to use the secret handshake either.
I have a TPC supercharger, it's been on the car for a little over 15K miles (I'm at 81K right now) and it provides a nice bump in HP and torque. I didn't install it, it came with the car but I'm very happy with it. The car's been very reliable, it doesn't leak or use any oil. That's my real world opinion having owned and driven a supercharged Porsche on the street and at the track. How many supercharged Porsches have you driven?
For the amount you spend on a supercharger you can certainly buy a turbo kit for your car on Ebay, but it will be made for a Honda. A real turbo kit will cost you a lot more than what you would spend on a supercharger, so you might as well buy a real Porsche turbo and join the "Real Porsche Turbo Dude" club. But I hear their handshake sucks. I've heard it on the internet and at Porsche meets, so it has to be true.
#38
#39
I drove a protomotive stage 1 964 before buying my car. I spoke to the shop that installed it and really not much more then a s/c installed plus you can always adjust the turbo down the line. The s/c you basically are stuck on the hp level but on the turbo you can upgrade and increase hp when you want to.
#40
There is a big difference in overall feel between a turbo and C2. Turbocharging a C2 will not make it feel or handle like a 965. The widebody, offset track and extra large trailing arms make it far more stable at higher speeds but not as nimble as the narrow body cars.
#42
(I'd join, but that initiation cost always pinched me.)
Private fraternal orders... heh. ("We meet upon the level apex and we part upon the square exit.")
#43
The one thought for everyone to consider is that, as our cars are all getting older and with high millage, the engine will need at some point, a complete rebuild which is a lot of money by itself. At that point the decision will be either to repair and keep the greatest car around or sell it for not a lot of money (because it needs a rebuild) and find the next best car around. If the decision is the former it may be a good time to add a turbo since everything is ripped apart anyway.
Just my thoughts although "I could be wrong"
Peter
Peter
#44
1 Post
Peter
Peter
Generally SC is a "more streetable" set up at it engages earlier vs spool up time for a turbo, plus overall installation is usually lighter.
current: 964 turbo look cab
94 Cobra - for sale (whipple blower @ 15p.s.i., 60lb
BAP, MAFia, fuel rails,Magnaflow exhaust, Cenerforce
clutch, some other suspension/chassis mods, on a
dyno@575rwHP)
past: Alfa 147 2L
bmw 323
bmw 318(modified)
American muscle (except for modified CRX)
#45
IIRC The protomotive stage 1 uses a small turbo low boost and produces considerable hp increase. Not unlike say an S4 2.0 turbo Audi. There is relatively no lag and spool up would depend on the turbo chosen. I know their stage 1 on a 3.2 will add upwards of 100hp and is very streetable. I don't believe compression reduction is required as the units only produce .4 bar of pressure unlike the factory which is closer to .9 bar using a monster K27 and is not much lower compression to begin with. These engines should handle it so long as it is healthy to start. Same goes for the low pressure used on the supercharger kits.
I agree as adding forced induction either sc or turbo will require low compression pistons forged internals (if more than mild boost is considered), and perhaps increase in engine size.
dyno@575rwHP)
past: Alfa 147 2L
bmw 323
bmw 318(modified)
dyno@575rwHP)
past: Alfa 147 2L
bmw 323
bmw 318(modified)
