Your lightweight/RS inspired 964
Well since the forum seems kind of slow lately (summer doldrums perhaps?), I thought I'd start a thread and see who has a 964 thats been built with a 'lightweight' or RS theme. Doesn't have to be extreme - just in the right spirit. I'll finally be back home in about two weeks and have a few parts waiting for me - seats, RS carpet, brake vents, etc. (the usual), and wanted to see what other listers have done with their cars.
Post em if ya got em!
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Here's mine, based on '90 C2:
Work Brombacher wheels
Evo intake
Chipped
FabSpeed/Dansk strait-thru exhaust
RS Perlon felt throughout, RS cards
RennLine aluminum boards
No sound deadening
Momo Monte Carlo
Airbag bypass bridge
Ruf A/R bars
Primary blower delete
PSS-9's
4 pot calipers all 'round
Slotted rotors
Recaro PP's with houndstooth inserts
993 TT plate, RS disk, LWFW
Getty Ducktail
H4's
All up @ 2801 lbs wet.
Evo intake
Chipped
No sound deadening
Momo Monte Carlo
Ruf A/R bars
PSS-9's
Slotted rotors
Getty Ducktail
H4's
Agent Orange
OK, I'll play:
My car...
Additions to standard USA Carrera 2:
- Fixed rear wing
- M030 Sports running gear
- M656 Without power steering
Deletions from standard USA Carrera 2:
- M650 Sunroof
- M331 Radio
- M573 Air Conditioning
- M454 Automatic Speed Control
Modifications:
Engine
- TPC Supercharger
- GHL headers and Fabspeed Dual Exhaust
- Carrera RS Motor Mounts
- Cat delete (CO2)
- Heat delete
Drivetrain
- Carrera RS Clutch
- Light Weight Flywheel
- Carrera RS 20/100 LSD
Suspension
- H&R Turbo Springs & Koni Adjustable Shocks
- RS Alignment
- Front Tower Strut Brace
Brakes
- 993 TT (Big Yellow) Front Calipers, 993TT Rotors
- 993 Rear Calipers, 964RS Rotors
- RS Front Brake Ducts
- ATE Blue Racing Brake Fluid
Wheels
- RH (Speedline for Porsche replica) 18x8 & 18x10 wheels
Body
- H4 Headlights with Yellow Lenses
- Tech-Art Front Chin Spoiler
Interior
- Recaro Pole Position Seats + Momo Sliders and Mounts
- G-Force 6-Point Harnesses
- DAS Bolt-on Sport Roll Bar for Nonsunroof Coupe
- Roll Bar Mounted 2.5lb Fire Extinguisher
- Momo Mod .07 Steering Wheel w. Porsche Crest Horn
- Rennline Track Mats
- VDO Boost-Vacuum/AFR/Volt Gauge
- Shift-I Shift Lights
- 993 Wide Sun Visors
Current weight: 2740 lbs
Current engine output: 327 hp / 331 torques
My car...
- Fixed rear wing
- M650 Sunroof
- M331 Radio
Modifications:
Engine
- TPC Supercharger
- Cat delete (CO2)
- Heat delete
Drivetrain
- Carrera RS Clutch
Suspension
- RS Alignment
Brakes
Wheels
Body
Interior
Ilko: Nice......very nice. What has your experience been with the Shifti install, set-up/calibration and performance since ? How/where have you located the lights - following the .pdf write-up w/ fab'd tab or otherwise ?
Obviously I was thinking of this 'lil toy as an addition as I'm starting to run out of project plans.
Agent Orange
Now with the shameless plug out of the way, let me answer your questions
The install was pretty easy. I did not splice any of the tacho wires, instead I was able to wedge the wire tips in the pins of the harness that goes in the back of the tachometer. Set-up was pretty straight-forward, the instructions that came with it are relatively clear. Just read them a couple of times before setting it up, because there are some timed executions that if you miss you'll have to start over. Performance-wise it's been flawless, however I find that I don't use it that much since in my case most of the torque is in the mid-RPM range and I upshift around 6K RPM anyway. The voltage meter function is pretty cool as well, but now I have a separate volt gauge in the radio slot, so I'm using that instead.
Regarding location, I've had it on two spots. My initial idea was to put it on the dash. Unfortunately the stock steering wheel is quite large and obstructs the view. So initially I had it placed on the steering column. Not exactly in the line of sight I thought, but it was quite visible - the LED's are quite bright and... they reflect on the windshield DIRECTLY in your line of sight - like the current M5
Here's what it looked like:
Now I have the Momo wheel and have relocated it on the dash, directly in line of sight:
Hope this helps.
Evo intake
Chipped
No sound deadening
Momo Monte Carlo
Ruf A/R bars
PSS-9's
Slotted rotors
Getty Ducktail
H4's
Evo intake
Chipped
No sound deadening
Momo Monte Carlo
Ruf A/R bars
PSS-9's
Slotted rotors
Getty Ducktail
H4's
The exhaust note is the most unique sound I've ever heard from a flat 6.
Evo intake
Chipped
No sound deadening
Momo Monte Carlo
Ruf A/R bars
PSS-9's
Slotted rotors
Getty Ducktail
H4's
Evo intake
Chipped
No sound deadening
Momo Monte Carlo
Ruf A/R bars
PSS-9's
Slotted rotors
Getty Ducktail
H4's
Thanks!
Paul - coming from the owner of such a gorgeous, correct 965, I'll take that as high praise indeed. BTW, weather looks promising for a bit of bench racing @ AutoZone Sat. morning. Hope to see you there. And bite the bullet and do the Grattan DE in October, eh ? Absloutely love the 965 color - looks analogous to Arnold dressed in his governor duds. May have the veneer of civility but don't **** with him...ever, you'll lose !
Carpet shots I had in stock:
Hope those help. Bear in mind that this job is a very serious bitch. You will reach a point where you stand back and wonder what the bloody hell you've done (and why). But, it was all worth it in my opinion and results are very pleasing.
To wit: Porsche glue recipe used under carpet/insulation material apparently has come direct from God himself. I struggled to understand how mere mortal humans could have conjured up a material that sticky.
Best.
Best.
917K, Oops, sorry I'd forgotten you already done the carper install and know the fun of such. My God man, you're actually considering doing it again ? Are you related to the Marquis de Sade ?
Thank you very much. The felt doesn't look too bad to me.
In regards to Porsche glue, I had almost no leg hair left after the last carpet job. I won't wear shorts next time...
Thanks for posting carpet pics... I was gonna do silverknit myself but now i think i may save myself some money and go with the felt.. your car is awesome btw
You've seen it before but here is some info and pics of my car. It weighs 2660 lbs.
Suspension:
Bilstein factory RSR dampers and twin springs
RSR monoball top mounts
Powerflex bushings in the front
RS tie rods
Manual steering rack
RS/cup sway bars front & rear
Tarrett monoball rear drop links
Front strut brace from Kremer racing
Brakes:
Big reds, front
Small reds, 3,6 turbo, rear
No break balance valve
Pagid pads
Transmission:
RS/cup flywheel
996 cup sinter clutch
996 cup LSD
RS shift lever
Engine:
Cup pipe
RS-DME
K&N filter, open box
Bypass pipe for rear blower
A/C removed
RS engine mounts
Body:
Cargraphic front splitter, 3,8 style
993 rear window spoiler with 3rd break light
air ducts front
Carbon fiber front hood with hood pins from Porsche motorsport
993 windscreen
Cup tow hook front
Big washer bottle removed, replaced with the smaller RS bottle
Smaller battery
Yellow lenses, no trim rings
Cup style stickers
Front bumper without headlight washers
Interior:
Lightweight carpets, no sound padding
RS door panels
Sparco Evo seats
Full Heigo roll cage with race harness
Momo/Porsche motorsport steering wheel
Blank outs buttons/panel for radio, front fog light, rear window
Emergency cut out switches in/outside from Cup
ABS-kill switch from Cup
Wood floor boards and washer, Cup replicas
I think that's about it!
Thomas
Suspension:
RS tie rods
Brakes:
Big reds, front
Pagid pads
Transmission:
RS/cup flywheel
996 cup LSD
RS shift lever
Engine:
Cup pipe
RS-DME
A/C removed
RS engine mounts
Body:
air ducts front
993 windscreen
Cup tow hook front
Smaller battery
Cup style stickers
Interior:
RS door panels
Sparco Evo seats
Thomas
