Monday- What have you learned?
Similar to the Friday thread, what did you learn over the weekend? anything good?
I haven't done any P-car work this week, but I did paint the bedroom while my wife was flying to Arizona. My daughter was asleep on the bed most of the time.
I started up the car on Firday afternoon after 5 months of winter sleep. Everything was perfect except that the ABS warning went of all the time. I thought I'd done something wrong when I installed the ABS-kill switch (as on the CUP cars) but I couldn't understand how so I started with the ABS-sensors instead because I disconected them when I put on some heat covers (also from the Cup-cars)....and guess what - I had put the connector for the left rear wheel in the wrong hole in the white socket! So it was a simple fix this time and now the car works as it should again! Learning - check, and double check!
A mis-adjusted throttle cable, not fully clicking the Idle microswitch while off-throttle, WILL cause rpm-hunting and stop light stalls.
(And that this will have gone undetected by every shop you've taken it to over the last 1-1/2 years... )
And that the throttle cable adjustment is under the car, just in front of the tranny.
And that these cars, when adjusted correctly, are soooooo sweet to drive.
1 Post
That if you spin just right, you only lose a few seconds...
http://www.youtube.com/watch?v=V8zNjZ66Gz4
Burgled
I learned that contorting myself while working under my tractor that broke down in muck along a swamp on my property it hurts like hell the next day after using muscles that have been sleeping all winter
Its not easy getting black muck off you skin!
I also learned the Sirius radio antennas suck as I just had to order my 4th in just over a year
I learned that sometimes hole saws come a little ****-eyed, and trying to use a crooked one on tubing does not work very well. Also figured out that when said hole saw is on a notcher, you can slowly spin it and using a sharpie/marker figure out the "high side" and then stop and take a heavy-ish hammer and knock it back straight.
Oh yeah, and forgetting to turn the gas on with a MIG produces really crappy results.
Likewise I learned that climbing up and down a ladder to put new siding on dormers results in Monday morning leg pain. Or maybe it was contorting myself underneath the kitchen sink when re-plumbing it. Either way, Ouch. I also learned that if you set up a table saw and a power miter box saw in the front yard, wear a tool belt, and brandish a 30 foot extension ladder, people you don't know will stop in your driveway and ask if you can come give them a quote on siding work. People you do know will stop by to ask how you learned to do this. To which I respond, "Learned? I never learned. I am just sort of winging it. When I am done I will have learned how to do it."
On a related note, Hardi Board, the fiber cement "hardboard" stuff is really amazing. If I could afford to put it on my whole house I would.
