Need 964 Crankshaft
Need 964 Crankshaft
I'm looking for a used "standard/standard" 964 crankshaft, that is both the main and rod sections are within spec. I do not need a crank that has been repaired.
Any leads will be greatly appreciated.
Please PM with details.
Mark
AFAIK, "standard" refers to meeting spec at the bearing section. Since there are two different sets of bearings (main & rod) a completely stock crank is "standard/standard". My crank has problems with the rod bearings, but the mains are fine.
Dave
Dave
Thank you, thank you, The reason I asked is, I've been curious as to why in the Performance Products catalog they list Perfect Bore barrels in 102 mm for 3.6 and 3.8. I thought the differance would be in the stroke, I guess not.
102mm barrels for the 3.6 have a base-sealed slip fit 107mm spigot.
102mm barrels for the 3.8 have a side o-ring sealed 109mm spigot as used on the 993RS & Cup engines.
