flywheel sensor
Originally Posted by Indycam
"I got a good trace on the oscilloscope but no voltage at all."
Do you know how to read the scope trace for the voltage ?
I have got my battery on charge again and will have another play about tomorrow,
I did not check for voltage with the scope , I used a voltage meter to test for the voltage
Dave
http://www.doctronics.co.uk/scope.htm
Try test a aa battery
Try test a 9 volt battery
Try test the car battery
Watch the trace jump up and down from the 0 line to 1.5 ish/ 9ish/ 12ish . figure out the VOLTS/DIV **** vs the vertical scale .
Then reread the flywheel sensor for voltage with the scope .
I think so but it is baffling , I definately got nothing on the multimeter .
I definately got something on the scope,
maybe its the earth at 47 thats got the problem, I will spend some time with it tomorrow .I kept testing the multimeter on the other live pins just to make sure it was definately functioning correctly.
Dave
Dave
When a scope and a multimeter disagree , go with the scope .
"I think so but it is baffling"
For the trace to jump up , voltage , there must be . The trace will not go up or down without voltage .
Hi
Still a bit stumped here, had a guy take a look taday and he says it could be the hall sensor, the wires to the sensor do look a bit dodgy.
My question is will the hall sensor stop the spark
Dave
Dave
Thank you thats what i thought.
I have read that the hall sensor will not allow the car to start, so i take it a faulty sensor will still spark but not start is this correct ?
Dave
Dave
"I have read that the hall sensor will not allow the car to start, so i take it a faulty sensor will still spark but not start is this correct ?"
Not correct! Bad info. The Hall sensor is ONLY used for sequential injection and knock control.
The engine will start and run without this sensor.
