flywheel sensor
#62
Indy
I am in a difficult position at the moment, I have 2 choices,
Firstly to send the DME to the states for diagnosis and repair, total cost including postage and insurance about £400.
Secondly buy one from a breakers yard, I have been quoted about the same figure.
either way does not guarantee that my car will start , although i am fairly confident i have done all the tests you never can be sure, you have not eliminated everything.
Also I do not have the money to speculate with at the moment, i am currently on embarrassingly low wages, If I knew 100% i would send it off straight away and get it fixed.
If only I could get hold of another DME unit just to test and eliminate everything else.
I suppose I will have to make a decision soon, my worse nightmare would be to send it away for repair only for my car to still not start.
yours undecidingly
Dave
yours undecidingly
Dave
#63
Dave,
There are a couple of places in the UK where you can send your ECU for assessment/repair. Try Camco in Warrington, 01925 445688 (they don't have a website as far as I know), or the ECU Doctor 01752 346437 here . The ECU Doctor may be a better bet, they're based in Plymouth. They charge £35 to test the ECU including return carriage, and £90 plus parts for repair. Best to ring them first to check that they can test your particular ECU. I know Camco repair Bosch units, and there is an official Bosch repair centre somewhere in the UK.
Barry
Barry
#64
Dave,
Buy yourself a copy of 911& Porsche World in Smiths ?. Look at the ads in the back .
Going rate for a good 964 DME in the UK is £250 tops . £400 is mug territory !!
There is a guy Crispin Manners ?? who operates from the Exeter area . Might be worth giving him a call ?? Maybe someone on Rennlist has his number ?
No affiliation etc , etc , just seen some good reports in mags.
Good luck
Geoff
Good luck
Geoff
#65
Barry
Thanks for the ECU doctor info, I have just spoken to him and its very optimistic, he said if he cant fix it then at least I get to have a free diagnosis , He seems like a really nice guy, very helpful.
For the first time in ages i am more positive about getting my car back on the road, I did not really fancy sending it off to the states, although Loren has been very helpful.
Geoff
I phoned the breakers who advertise in that mag and they quoted me £400 exchange on a second hand unit , I dont know if that included tax and postage.
I would like to thank everyone who has helped me over the last few weeks< I just hope this Doctor guy is the answer
Dave
Geoff
Dave
#67
Originally Posted by david@st ives
Lauren
I only had one scope lead so tested pins 47 and 48 with it
Pin 47 nothing
Pin 48 got a trace , well it looked like 3 seperate traces together if you knoe what i mean, i dont fully understand the scope 2 traces had high peaks and the third was a lot shallower .
Dave
Pin 47 nothing
Dave
Dave
#68
47 is the signal ground on M2.1 so no signal. If you adjust the scope timebase /
trigger while looking at 48 you will see the crank sensor signal with " missing tooth " . Loren probably has a pic of this on his site ?
Have you taken the DME out of the car and had a look at it ? Damp is bad !!
Geoff
Geoff
#69
Geoff
i was just making double sure about pin 47 , i got a trace as for how to use the scope properly is beyond me but i definately got something so i assume "something" is ok considering i got the correct voltage and ohms.
I opened the DME and everything was bone dry , with no obvious signs of anything wrong.
I have now got the DME wrapped up ready for posting tommorrow so for £30 i will have an answer as to whether it is the DME or not.
Dave
Dave
#72
Its not the ECU , just had a call back to say the ECU performed perfectly on the test rig.
Dont know if thats good or bad news ?
Any how i get a remap and all the parameters set to within 5 % of origanal settings if they are out slightly.
The guy told me to double check the earth wires, pins 2 and 19
Does anyone know the earthing points where these wires go to.
Confused , I am now
Confused , I am now
#73
I have just tested the earth wires and everything ok,
I have just tested pins 47 & 48 again
I could not get a voltage reading this time around, where does the flywheel sensor get its voltage from ?
the ohms test was OK 517ohms and I got a good trace on the oscilloscope but no voltage at all.
