Spacers and Cup2 with mega ET
Hi,
I got a set of 17” Cup2 in a car-deal, the front is 7-ET55 and rear 9-ET70.
Im planning to use them on a std 964-92.
My question is spacers, what do I need to install them?
Best regards
Anders Kaarle
Best regards
Anders Kaarle
Hi,
Thanks för yor help.
Could I use the following spacer?
https://shop.fvd.de/main.php?sm=&mod...total=30&back=
Best regards
Anders
Best regards
Anders
Originally Posted by raacer
You will need to change out the studs for a longer version.
Generally shims are only available in sizes of 5 or 7mm. Anything larger will usually have integral studs. It DOES mean, however, that you have to be careful with which wheels you fit since not all wheels will accomdate the bolt heads which hold the spacer to the hub.
I've used the word "generally" above since it is not ALWAYS the case so don't start flaming me about exceptions - I know they exist!!
Regards
Dave
Super Moderator
Needs More Cowbell
Needs More Cowbell
FWIW, here is some wheel info from my 964 Cup:
https://rennlist.com/forums/964-forum/270747-anyone-out-there-running-9-5-x-17-cup-1s.html
The Carrera Cup rear 9.5 wheels are 68mm offset and are run with a 21mm spacer, 477.501.701 (944 rear wheel spacers IIRC). No rubbing issues, although the fenders are factory rolled.
The front 8's (same as RSA rear wheels) are 52mm offset, no spacer and I don't have any rubbing.
http://www.carreracupusa.org/Race/wheels/wheels.htm
Here is a thread with some additional info on spacers/offsets:
https://rennlist.com/forums/964-forum/314645-964-wheel-questions.html
https://rennlist.com/forums/964-forum/316567-8-and-9-5-cup-1-a.html
https://rennlist.com/forums/964-forum/242599-are-you-spacing.html
