964 Forum 1989-1994
Racecar Project - RS Shift Assemby
Old Jan 6, 2006 | 09:35 PM
Geoffrey's Avatar
Geoffrey
Default Racecar Project - RS Shift Assemby
I purchased an RS Shifter, shift fork, and shift rod to replace my stock C2 parts which were worn out. Here are some pictures for comparison with teh RS Shifter parts on the left. The shifter is longer from the pivot point down which changes the throws and makes them shorter. The RS Shifter then also sits higher so it is easier to reach. The rear of the shift rod has a solid u-joint rather than rubber or plastic bushings which in my case were worn out. You can see in the pictures the space between the rod and the plastic insert which allows play. I have also replaced the front ball and socket with a heim joint to replace the plastic insert in the ball and socket. (pictures to post when complete)
Old Jan 7, 2006 | 12:47 PM
ThomasC2's Avatar
ThomasC2
I did this on my car to, but skipped the shift rod and just replaced the plastic bushings. Totally pleased and this is a cheap and easy upgrade I would recommend every one. Especially instead of buying expensive short-shift aftermarket kits when you can have real Porsche parts.
Old Jan 7, 2006 | 01:03 PM
MARC A. 964 C4
Guest
Posts: n/a
BTW, how's the leg? As usual thanks for the interesting text and photos. As so many I feel very involved in your project.
All the best from France, Marc.
Old Jan 7, 2006 | 04:44 PM
Cupcar's Avatar
Cupcar
25 Year Member
My car came with the RS shifter but I changed to the later 993 RS shift rod pictured and it is much nicer with it's metal to metal bearings. I found that, due to wear in the plastic bushings, the original coupling tended to develope significant "slop" over time.
BTW the original coupling was used in the 356 and earlier 911 as well....talk about heritage!!
Old Jan 7, 2006 | 05:53 PM
MarkD's Avatar
MarkD
So, instead of buying an aftermarket kit by B&M or whoever, I can buy RS parts to accomplish the same thing? Cool. I have heard some less than desireable things about the B&M kit... was thinking of looks at a couple of the other brands that were available.
I suppose I can just use the PET to ID the 3 or 4 parts needed.
BTW, thanks for the great posts Geoffrey. Watching this car evolve has been very educational.
Old Jan 7, 2006 | 06:14 PM
Cupcar#12's Avatar
Cupcar#12
Gert actually sells the Kit (it's a euro part)
2 parts - the Lever and Fork and the Rod assembly
http://www.carnewal-europe.com/cpx_p93104.htm
Old Jan 7, 2006 | 07:14 PM
MarkD's Avatar
MarkD
forgive my ignorance... but "P93" = ?
Looks like it means C2 but where does this designation come from?
Also, I would only need the lever and fork? The rod is the same c2 vs. RS?
Thanks!
Old Jan 7, 2006 | 07:37 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Post
Thanks!
P93 = Porsche 993 series.
C2 and C2S were the 993 models mentioned in the link.
Old Jan 7, 2006 | 09:22 PM
Geoffrey's Avatar
Geoffrey
My leg is healing nicely, thanks for asking. I still cannot do resistance training and bicycling is out and fortunately it is winter because rock climbing is out too Hopefully it will be much better in a few months.
You can also get the RS parts directly from your local dealer.
Old Jan 7, 2006 | 09:35 PM
MarkD's Avatar
MarkD
hate to beat a dead short-shift question...
but the P93 parts suggested via carnewal seem to NOT be for a 964... so I guess I can just get the RS parts and be done with it? And I would need 3 parts, right?
To add to my confusion the only part I see listed that is RS specific is the fork.
Not trying to be dense... comes naturally.
Good luck on the recooperation.
Old Jan 7, 2006 | 10:49 PM
Geoffrey's Avatar
Geoffrey
The shifter and shift fork are 964 parts used in both the 964 RS and the 993 RS. The shift rod is a 993 RS part, not used in the 964 series cars, but is interchangable.
Old Jan 8, 2006 | 03:13 PM
burgass's Avatar
burgass
Guys, I think the B&M short shift has a shorter trow than the OEM RS. For those of you who own a C¤ the only available short shift is RUF`s.
Old Jan 8, 2006 | 04:27 PM
viperbob's Avatar
viperbob
Former Vendor
I am assuming here that you mean a C4? If so, you can still use the exact same RS factory lever / shifter. The difference being that 1) you need to cut about 1" off the top of the shifter to keep at the same height in the cockpit 2) you do NOT need the fork with the C4 and 3) you will need to dimple the tunnel cover in order to clearance the shifter (which makes sense if you look at Geoffrey's pic as the lower portion is longer from the pivot point, and you CAN NOT move the pivot point with the torque tube like you can with the simple shifter box).
I have installed maybe 100 of these shifters (many C2/C4 and 993 Turbos) and they work great. Makes a big diff and very little $$$.
Oh and that RS shift rod with the nice u-joint went up recently at Porsche. They use to list for around $225. They are now like $425.
Old Jan 8, 2006 | 05:00 PM
burgass's Avatar
burgass
Yes I mean a C4. I am aware that you can fit a RS in a C4 with modifications but personally I did not like the idea of dimpleing the tunnel cover and not being able to move the pivot point. So...I emptied my pockets for a RUF item.....a lot of $$$$$
Old Feb 14, 2006 | 12:19 AM
jim dorociak's Avatar
jim dorociak
Veteran: National Guard
question for everybody. is the shape, length, bends the same on the stock shift rod and the 993 RS shift rod? is the only difference the ujoint on the RS shift rod? thanks! Jim
