964 Forum 1989-1994
Pending projects and a few q?
Old 04-05-2009, 10:26 PM
  #211
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Originally Posted by MA7008O
Are this the only tools needed to remove the exhaust?
Add a phillips and flat head screwdrivers, one more 13mm wrench, 10mm wrench for the smaller bolts that hold the muffler bracket... some rtv silicone to put a dab on the header gaskets to keep them defying gravity... and long 10mm,13mm, 15mm sockets... I think that covers the tools... will do inventory when putting everything back and update the list.
Old 04-05-2009, 10:30 PM
  #212
Wachuko
Wachuko's Avatar
Originally Posted by crg53
As you can see in the picture in my last post, I cant' get the muffler close enough for the pipes to reach the header. I can drop the muffler further down, but then it hangs down below the back of the car, and will scrape. That muffler should be up out of the way and out of sight. What I need are some longer pipes.
I am with you on that... looks as if the elbows that go from the muffler to the headers need to be a little bit longer for the muffler to be completely out of sight...
I will email Fabspeed to have them take a look at the thread and see what else they can comment on it.
Old 04-05-2009, 10:32 PM
  #213
Wachuko
Wachuko's Avatar
Originally Posted by doug751
Hello Jaime,
Thanks for taking the time to document the exhaust installation.
Do the exhaust ends stick out far enough on a 964 if the oval tips are not installed? Hard to tell from your photo.
Does it seem like it will be easy to bottom out on the headers?
I ordered the tips to be welded once I have everything aligned... so not sure if they sent me different pipes. As it is, without the tips, they sit a bit into the bumper... so no way to use them like that (without tips) in my case since that would end up in a melted bumper...
Old 04-05-2009, 10:45 PM
  #214
Wachuko
Wachuko's Avatar
Cool
Let me place the two photos for comparison...
Yours with the muffler nicely hidden...
Mine (I will try to get a photo from the same angle as yours for better comparison)...
Old 04-06-2009, 12:13 AM
  #215
crg53
crg53's Avatar
Wachuko, I did email Alex at Fabspeed, to let him know I was having a bit of trouble fitting the muffler, hopefully he wil have the answer. It sure is a fine looking system, and I did hook it all up yesterday, but without the heater pipe in place, started it up, and man does that sound good, I cant' wait to get it all finished.
Old 04-06-2009, 03:58 AM
  #216
MA7008O
MA7008O's Avatar
I'm having a hard time removing the 12 hex nuts that holds the header to the cylindres...
Old 04-06-2009, 09:58 AM
  #217
Wachuko
Wachuko's Avatar
I had removed the left side header not too long ago and used anti seize on the bolts before putting it back, so that side was easy to take out... on the other side I soaked the bolts with penetrating oil several times, warmed up the car a bit, soaked on penetrating oil again... still those two were difficult to get out. One came out with stud and all...
Old 05-23-2009, 11:39 PM
  #218
Wachuko
Wachuko's Avatar
Cool
Since one of the side markers was loose (broken tab) I went ahead and updated the side markers to clear units...
Old 05-24-2009, 10:00 AM
  #219
hawk911
hawk911's Avatar
Jaime, mine doesn't have those. Did you add those at some point?
Old 05-24-2009, 10:56 AM
  #220
Wachuko
Wachuko's Avatar
Cool
Remember mine is a gray market car that came from Sweden. US cars don't have those.
Old 05-24-2009, 11:15 AM
  #221
hawk911
hawk911's Avatar
Ah- I didn't know that yours was grey; I thought it was Red
Old 05-24-2009, 11:27 AM
  #222
Wachuko
Wachuko's Avatar
Cool
yeah... the 996TT is gray, the 964 is Guards Red Gray/Grey
Old 06-05-2009, 10:02 AM
  #223
Wachuko
Wachuko's Avatar
Cool
Redesigned parts for the Fabspeed muffler came in. Started installing these last night... then, while in there... decided it was time to take out the bumper, get the corner painted and install... paint the spoiler... So it is disassembly time!
I removed the muffler and put in the straight pipes so I can work on removing the bumper and still be able to move the car around.
Started last night (around 10:30pm)... I will setup the lift this afternoon to make it easier to work under the car.
Nice big oval tip
Starting to take the bumper apart...
More to come....
Old 06-05-2009, 10:53 AM
  #224
pete000
pete000's Avatar
With that Fabspeed system you do not run the rear engine tin????
Old 06-05-2009, 10:59 AM
  #225
Wachuko
Wachuko's Avatar
Cool
You could... but I took them all out... call me crazy but I like to look at the engine... wife will sometimes find me laying on the floor under the car day dreaming I really enjoy looking at all the details on the engines in these cars...
Anyway, I figured, that without all those covers, I can clean it better and have better, quicker access when doing the maintenance.
Quick Reply: Pending projects and a few q?
