Group Buy High Quality Billet 951 8V Adjustable Cam Gear
#92
Rennlist Lifetime Member
I haven't been around in a loong time, but a long time ago, I worked with Jeff on an adjustable cam gear group buy. One of those gears is pictured on the previous page and alllows +/- 4 degrees of timing change. I dealt with Jeff personally at length. He is 100% a stand up guy and I'm certain that whatever he has committed to make, he will deliver.
#93
Rainman
look on the bright side, if you had changed your timing belt when this group buy started, now there's only 2 years left until you go in to do it again!
perfect time to put the gear on, if they're available by then.
#95
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Hello, well...
Yes, and No is the true answer. I call him once a month and get the same answer it will be done soon. Trust me, I am extremely upset about this but still waiting. As soon as I have anything concrete I promise I will immediately post status. I sincerely wish I had more, but I don't. It is out of my control.
#96
#97
Rainman
Hello, well...
or found another machinist.
mission critical aircraft parts don't take this long to manufacture.
#100
#103
LMAO!!!!! And 16 months is 1.3 years. Wait two more months and I'm sure they'll be ready by then. Or not? Noooooo! You know if you went with the 16v head you wouldn't have this problem right? Because the 16v cam gear is factory adjustable. Oh Noooo. Or get this off evilbay.
https://rover.ebay.com/rover/0/0/0?m...2F252995982618
#104
Professional Hoon
no need to derail the thread also.
