86 944T Front Suspension Overhaul
I'm looking to refresh my stock front suspension on my 86 944T. Getting started on finding the best setup (Paragon, etc.). I took the car to my local P Specialist and they were quoting me way above what I want to pay in labor.
Has anyone tackled this job themselves? I've done some research and it seems relatively straightforward. Anyone in the Philadelphia/NJ region that is knowledgable and would be willing to help? Compensation and Beer would be a part of the deal.
You can do it. There's nothing in there that's really difficult. What specifically are you planning on doing? Basic hand tools and a torque wrench are all you really need.
http://www.paragon-products.com/Coil...ni_cup_kit.htm
This tech article looks helpful.
http://www.pelicanparts.com/techarti...eplacement.htm
Call that shop from a new number and ask what they charge to do the same work on a Mk1 VW Golf. If its less, they are taxing you for the badge, the suspension is basically the same on the 944 as that golf. Parts are more money, but the labor is the same.
Do it yourself, its the same as any other McPherson strut car, there is nothing difficult about it.
Thanks guys. I did call the shop back and the quote was the same. I think it just comes down to the job taking some time and at 130/hr. it adds up quickly on top of the parts cost. I'm definitely going to tackle it myself, it's now just a matter of developing a checklist of all the parts I need to refresh while I'm in there.
I'll continue reading the countless suspension threads but welcome any recommendations on suspension components you've had success with.
Rainman
You can remove the entire front suspension (without the crossmember) in about 20 minutes...easy to work on stuff when it's all out of the car.
Looking to get the bushings kit and thinking about the Koni Cup 1 kit from Paragon. Anyone have experience with this kit?
Here's some pics of our control arm rebuild for the chump car.
http://straightpipe.ca/forums/showth...?t=2454&page=4
The Koni shocks are pretty easy to do with minimal tools. Just take your time and measure everything twice. The only tricky part is if you are going to do the control arm bushings and ball joints.
The Koni procedure is definitely doable:
https://www.paragon-products.com/kb_results.asp?ID=50
I'd do it all yourself and then pay for an alignment. Keep in mind that the current Koni sale ends on the 5th at midnight.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
Thanks Jason. Would the full coil-over kit require the same strut conversion?
