Intake and Exhaust block off plates
I'm gauging interest in block off plates for the intake and exhaust ports for the 2V head.
Have 2 options for design. One plate has 4 bolt holes that will work on either location with proper alignment......User must select appropriate hole location.
Other option is 2 different plates, one plate for the intake and one plate for the exhaust.
Both options use an o-ring to seal off the port.
Each option will use your stock intake bolts with washers.
I'm making some for myself
Is anyone interested in this if I make extras?
They will essentially look like an intake gasket without the port hole.
Hope everyone understands what I am getting at.
I don't like using a rag to keep contamination from getting down the port when doing work. With the o-ring it will also seal it from liquid.....reason I am having an o-ring groove put in it. O-ring would be included.
This has been designed by myself and a P-Eng friend.
Thanks,
Jason
Thanks,
Jason
Wow LOL only one person so far ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Going to talk to my Engineer friend who will make them. I'm going to do a run of the 4 hole version to start. Should have them next week and will post a pic.
Too bad it was not winter, I would be happy to hand deliver them to Hawaii![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I will post a pic a soon as I run the first batch. Have to do min quantity 16 of them.
Jason
Jason
I'm guessing your meaning to create a custom intake like Refresh951 without having to cut up an intake??? If so I will definitely talk it over with Engineering friend ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
