16v head and turbo myths
Old 05-18-2023, 06:17 AM
  #181
sherry66
sherry66's Avatar
Yes , the cam wheels are affordable Pat . Its like a moving billboard for DRS .
If people want a moan about money wasted on modifying a car , buy a boat . Now that really is a good way to get rid of your cash . Depreciation, maintenance , fuel , berthing etc . At least we all own our cars and can shut the garage door for a while when it gets to much .
Jay Wellwood (05-20-2023)
Old 05-18-2023, 06:27 AM
  #182
blade7
blade7's Avatar
Was running the balancer shafts an option for that engine Simon?
Old 05-18-2023, 07:08 AM
  #183
Penguinracer
Penguinracer's Avatar
Everyone's standards are different - to me a modified car should be at least as durable and reliable as a top of the range factory road car (NB. not a factory race car) e.g. ability to circulate a track non-stop for as long as a GT3 and then reliably drive home across Europe without having to touch anything. That's a mature well engineered build as opposed to backyard lash-up. I've spoken to people who wouldn't take any wet-sumped car to the track ( ex Carrera Cup driver) and for some that might be an overly conservative position. I consider my Setrab 925 oil cooler to be minimal, so I have a 934 as a spare. The Porsche cooling loops for power steering & transaxle cooling - fine for a road car but totally inadequate for the track - again Setrab to the rescue.
If my car won't be able to run as many (non-stop) laps as a GT3 or my brother's mapped M2 Comp - then to me I've failed - it's a poorly engineered build.
Droops83 (05-18-2023)
Old 05-18-2023, 07:42 AM
  #184
bergerac
bergerac's Avatar
Lovely, is hood clearance an issue on the inlet cam wheel though? Is there a source of suitable turbo cams now that rsbarn has shut?
Old 05-18-2023, 08:35 AM
  #185
Penguinracer
Pictures as requested:
Billet control arms, billet hubs, new M030 spindles, ER spherical, Garrett Bars, Big Blacks, LR Dry Sump, Ceramic coated SFR headers & exhaust, Wizard radiator, SFR Stage 2 Intercooler, Sebrab 925 oil cooler, Setrab SLM 114-14 PS oil cooler, twin 13" Spal VA13-AP70LL-63A 1720 cam fans
Old 05-18-2023, 08:43 AM
  #186
Penguinracer
Setrab transaxle oil cooler
Old 05-18-2023, 08:52 AM
  #187
Penguinracer
ER sphericals & Quick Change Spring Plates & 28mm Torsion Bars, Tarett ARB, KW Clubsport 2-way, Guard 50/80 LSD
Old 05-18-2023, 09:01 AM
  #188
Penguinracer
2.7 litre, Darton MID (104mm bore) SFR intake & 70mm TB, SFR N/A stage 4 cylinder head, Ferrea Super Alloy valves, Garrett GTX3576 Gen II, Tial 0.83 hotside, SFR Stage 2 fuel system, ID 1300X injectors, Milledge SR8-14A cam, LR valve springs, Cometic MLS HG, Mahle 8:1 pistons, Carrillo rods, LR dry-sump, Clewett cam trigger, TTV 60-2 flywheel crank trigger, Emtron KV8 ECU, Emtron CDI ignition, Emtron COP, Tial 46mm WG, twin Bosch 044's from 1.5 litre swirl pot, Mitsu alternator
Old 05-18-2023, 09:06 AM
  #189
Penguinracer
2.7 litre, Darton MID, Mahle 8:1, Carrillo rods, SFR intake & 70mm TB, SFR Stage 4 cylinder head, GTX3576 Gen 2, Tial 0.83 hotside, LR dry-sump with AOS, PS, Milledge SR8-14A cam, Ferrea super alloy valves Clewett cam trigger, TTV F/W 60-2 crank trigger
Monterey (08-25-2023)
Old 05-18-2023, 09:09 AM
  #190
Penguinracer
3 US gallon Peterson dry sump tank & breather, 1.5 litre swirl pot - in spare wheel well. AN -16 lines to & from tank with AN -12 for AOS return line
Old 05-18-2023, 09:13 AM
  #191
Penguinracer
Twin Bosch 044's & filter from Swirl Pot. Bosch 044 lift pump from tank. All feeding SFR Stage 2 fuel system & ID 1300X injectors. Located in space behind right side rear wheel arch under boot floor. Sealed by a stainless steel cover
Old 05-18-2023, 09:16 AM
  #192
Penguinracer
Zircotec ceramic coating on SFR Stage 1 headers. Remainder of exhaust system & cross-over, down pipe etc 3" SFR with a Borla XR-1 muffler , ceramic coated to half of entire exhaust system length
Old 05-18-2023, 09:25 AM
  #193
Penguinracer
Brak cooling ducting to LR stainless steel backing plates, Single piece 322mm front disks, also have two-piece slotted disks with black LR hats, Pagid RS29 pads, titanium pad backing plates, KW club sport 2-way, Wheels - 18" 993 Hollow-spoke and a set of new Fuchs forged 18". Tyres - two sets - Yokohama A048R & A052R, sizes: F- 225/40/18, R- 265/35/18, Billet A-Arms & Billet hubs, new M030 spindles drilled & threaded for A-Arm pins
Old 05-18-2023, 09:27 AM
  #194
Penguinracer
Original matching numbers block, crank & transmission.
Old 05-18-2023, 09:34 AM
  #195
Penguinracer
SFR Stage 2 intercooler, Setrab 925 oil cooler, Wizard radiator, Twin Spal VA13-AP70LL-63A 1720 cam fans, Setrab SLM 14 row PS oil cooler, brake ducting, front left plate to be removed to accommodate air intake filter above brake duct feeding turbo via 4" AIRAID ducting
Quick Reply: 16v head and turbo myths
