Building a 3.0L Turbo motor.
#61
Here was my original build thread, though it's more issue de jure than building guide.
https://rennlist.com/forums/944-turb...ding-blog.html
Here is the thread once I got it started:
https://rennlist.com/forums/944-turb...e-3-liter.html
Here's a thread 81 days later when I blew-up the transaxle:
https://rennlist.com/forums/944-turb...ing-power.html
Since blowing up that tranny, I had Kevin Gross rebuild one, and it's held strong for the last 28k miles.
Here's a thread with a vintage dyno run:
https://rennlist.com/forums/944-turb...493-498-a.html
#64
#65
Tom did this in his home shop over time, while sharing honestly. This, in my opinion is the, "Best of Breed Success story you'll likely ever read towards what you've asked for towards a DIY 3.0.
Thanks Tom,
G
Thanks Tom,
G
#66
But I'l keep collecting them. It's taken me nearly a year to get this far, I can't see any reason to stop now, so keep those cards and letters coming.
Thanks again to everyone who's contributed. It won't be the last you hear from me, with luck the project starts in earnest in a couple of weeks. I have the car, the block, the head and the shop (at least for a few more months). I'll be posting plenty of status and questions.
#67
No modifications are needed on the head or block.
I hope the batch gets done by the factory within a month.
Edit: adding some info from Athena who will manufacture these gaskets
"High Performance Cooper ring Insert. For specific very high horsepower applications, a conventional or MLS Head Gasket can be significantly improved utilizing a different sealing system for the combustion area. Athena utilizes a proprietary INOX steel fire ring which offers improved sealing technologies over copper and conventional fire rings. This solution dramatically increases the cylinder head gasket resistance to extreme "
I'm hoping this to be the ticket for high boost applications on the 3 liter turbo engines.
#69
It's called "Cooper" ring gaskets. It's basically a pyramid ring type of gasket. It's very best in terms of head gaskets. You can look up "athena cooper ring gasket"....This solution dramatically increases the cylinder head gasket resistance to extreme "
So what will these little devils cost me and how do I get on the list for a couple (remember, never do something once when you can do it twice at double the cost )
#70
I was wondering the same thing. If you will have some extra hg's I'll be in queue. Or perhaps these will be available for purchase straigth from the factory later on? What will be the compressed thickness on these?
#71
Is the cooper ring the same principle as Cometic Phuzion gasket? http://www.frsport.com/Cometic-PH005...m_p_79077.html
#72
I've ordered a batch of 10 for the 104 mm blocks. If you're interested send me a PM. I don't have the pricing ready yet.
They differ from the Phuzion concepts as the rings in the Athena gaskets are not gas filled. They are inox rings with grooves that will cut a tiny bit into the head to lock the ring to the head. That mean that you might need to skim the head after a number of install/removals. But rings that cut into the head is the key to sealing.
#73
#75
I'd guess that they would recommend not having o-rings. With that said, the gasket will be fiber type with silicone strings (as this is much better than steel for water and oil) so it would probably also work with o-rings. As long as it's sufficient material towards the fire ring.
