View Poll Results: Can you use them?
Yes
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
1
8.33%
No
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
11
91.67%
Voters: 12. You may not vote on this poll
Bent valves.. un bent.
Professional Hoon
What do you reckon, Can you re use them?
I unbent my valves to take measurements for new ones. And they are in spec as the factory ones. Checked with a dial indicator on the lathe.
besides, its sort of impossible for them to be "perfectly unbent". When metal bends, it undergoes plastic deformation which permanently and irreversibly alters and stretches the material's grain structure. It can never be truly "unbent".
edit: off topic, but paulyy would you happen to have a link to that nifty excel spreadsheet you posted once that compared compressor maps? I liked it and I'd like to save it again, Thanks.
Professional Hoon
https://rennlist.com/forums/944-turb...am-inside.html
I've thought about this, and I have this to say...The worst you have to loose is a broken valve down the road and then you'll be replacing the valves anyway, and you're out a headgasket and your time. Absolute worst case is you kiss a piston. Or....you could run them forever and they could be fine. You could just toss em back in I suppose, but the engineer in me still says the bent point is a stress riser...just cant say for sure if/when it will become an issue. I'm crazy and a cheap bastard to boot, I'd at least consider throwing em back in and seeing what would happen if nothing more than for ****s and giggles.
Absolute worst case is that valve falls to one or more peaces and those absolutely destroy piston, head and bore to the point that all of mentioned peaces become paperweights and you need to build new long block for 50x the amount of new set of valves.
This valve cost me ~ $8k on my bmw in 2009. I ve lost cylinder, head and piston pictures, but it looked something like piston on the bottom.
Also bmw valve is a lot smaller and weights lot less than 8V 944 valve.
![](http://s9.mojalbum.com/599159_8084992_16987753/abc/16987753.jpg)
![](http://s9.mojalbum.com/599159_8084992_16987750/abc/16987750.jpg)
This one is from two stroke V4 Johnson outboard motor, no valve, but one needle from needle bearing got in the chamber and this is the result..
![](http://s9.mojalbum.com/599159_17688908_20660055/outboard-tampering/20660055.jpg)
But at the end of the day, any part that is machined should never be reused unless it is re-machined. And if it is hardened in any manner, it shouldn't be re-used unless it undergoes proper hardening procedures after it is done.
You may get away with it, but I wouldn't think about taking a chance, the valve may break, and then you are looking at a complete overhaul.
Professional Hoon
Note: I am NOT Reusing them. I was just seeing what people opinions are on doing it. Hence why i re bent them to get sizes to send off to get new ones made.
Basic Sponsor
This is bad Oman, I foresee Au losing to Holland today, your fault Pauly
Yeah, re-using them would pretty much be the height of stupidity.
Basic Sponsor
