S andS2 trans. Are they the same?
Old 03-25-2014, 04:03 PM
blown 944
blown 944's Avatar
Default S andS2 trans. Are they the same?
I may pick up an S trans. Curious if they are the same.
Looking at ideolas PDF it appears they are.F
Old 03-25-2014, 04:34 PM
Sixline
Sixline's Avatar
From what I found they are not the same. Some gearing is different and apparently the S2 transaxle has a stronger differential.
Transmission 083 F is the same in design and repairing procedures as the 944 S transmission 083 D, except for a few deviations.
Most Important Deviations:
- Longer 5th gear 36 : 28 i = 0.778
- Final drive ratio 8 : 31 i = 3.875
- Design distance "Ro" = 59.65 mm
- Stronger differential
Sources:
http://www.9ss1.dk/porsche944/garage/vol2/vol2.html
http://www.clarks-garage.com/shop-manual/trans-04.htm
Old 03-25-2014, 05:20 PM
Will Feather
Will Feather's Avatar
S/S2 trans will offer some nice acceleration if going into a turbo car....for the drag car?
Old 03-25-2014, 06:56 PM
turboS_swede
turboS_swede's Avatar
I would put the transmission bracing plate on whichever you choose, might as well prevent possibly breaking the case or damaging gears if you can avoid it:
http://www.gt40s.com/forum/gt40-tech...rsche-lsd.html
http://www.kitcentral.com/index.php?...t=2964&start=0
http://stweb.peelschools.org/sssweb/...tep/index.html
I'm putting an S2 transaxle into my 88TS since I didn't get it with the original trans, so might as do something different and tailor the car to my driving needs/style.
Old 03-25-2014, 07:25 PM
333pg333
333pg333's Avatar
99% sure that the r&p is smaller/weaker Sid.
Old 03-25-2014, 08:51 PM
blown 944
blown 944's Avatar
I was just going to pick it up since its cheap. I've used an s2 trans before, but I think that it'd certainly be too short of gearing now. Iirc, 4th gear winds out at 126mph.
I was thinking of experimenting with what I could do to improve my ET and run low boost.
If I could launch it harder I may me able to break into the tens with less power than I was making.
Old 03-25-2014, 09:09 PM
333pg333
333pg333's Avatar
Be kinda curious how you went with a stock 951 trans in terms of gearing? Might be slower off the line but possibly save you an extra gearchange depending?
Old 03-25-2014, 09:49 PM
V2Rocket
Rainman
V2Rocket's Avatar
jack up the rear and run taller tires with the S2 box
Old 03-26-2014, 03:54 PM
blown 944
blown 944's Avatar
Here is the PDF. It apears the r&p are the same. Might buy it and just try it.
http://garage.ideola.com/downloads/G...eteTinucci.pdf
Old 03-26-2014, 04:20 PM
333pg333
333pg333's Avatar
Sid, I think that's wrong. PM Sean / JET951. I'm certain he tried an rp from an S and guess what, Destroyed it at the drags. It was later established that the S2 version was bigger/stronger.
Pretty sure Jim / Oddball warned of this too.
Old 03-26-2014, 05:12 PM
glen2002
glen2002's Avatar
Sid, I heard the same as Patrick. I sold my old car to a friend telling him how good the S2 R&P was. He had Sean recreate the car, the R&P turned out to be an S and they dumped it, was ok for standard use but didn't think it was up to circuit use with a Stage 3 Vitesse. I imagine your use will be harder.
Old 03-26-2014, 05:17 PM
blown 944
blown 944's Avatar
Thanks for that info guys. I'll just pass on it then. Like I said, it was going to be for experimental purposes anyway.
Old 03-27-2014, 09:44 AM
67King
67King's Avatar
FWIW, part numbers are different, though ratios are same. Both are 016409143, but one ends in BF, the other BD. The biggest sign, IMHO, is the cost. The S2 one costs about twice what the S one does from Porsche.
Old 03-27-2014, 10:25 AM
KevinGross
KevinGross's Avatar
Different ring and pinion ratio, different fifth gearset.
Kevin
Catellus Engineering
Old 03-27-2014, 11:25 AM
67King
67King's Avatar
Kevin
I believe that both the S and the S2 have 9:35 (3.889) R&P's, do they not? Not sure about 5th, though.
Quick Reply: S andS2 trans. Are they the same?
