VW/Audi 07K (2.5L 20V I5) Swap Thread
#541
The ECU will function alone , but first it has to have the Immo deleted , Immo being the immobilizer system . This is a system many cars use these days . Some call it VATS , vehicle anti theft system . VW and Audi systems link the ECU , dash cluster and ignition switch key that contains a chip , to all be connected in the vehicle . The sites I have found deal with the older Motronic ME7.1 and ME7.5 systems . Main difference between these 2 are the ME7.5 is the later system that comes with factory wide band O2 . The system that come on the 07k is the Motronic ME17.5 , it is a totally different platform and none of the older softwares work for it . All of the interface software that will work with the ME17.5 is expensive from what I have found . If I have to spend $1000+ on some software ,,,,, I`m just going to go the the MS3 Pro Evo . I have experience using the tuner studio software that works with all the megasquirt platforms . As long as you run a wide band O2 sensor , you can tune the fueling part in real time while driving . You will have to spend a little time on a dyno to fine tune the ignition maps . I am now going to spend my weekend cleaning up and servicing my vintage barhop bike and put it up for sale to just go ahead and fund this project .
#542
It seems like the bellhousing design has been finalized, but is there any possibility of a removable panel like in the 968? Or would this somehow affect the SFI rating?
In addition to making clutch inspections/changes much easier, it would come in handy in the event of a leaking hydraulic throwout bearing/slave cylinder . . . . .
#543
#544
How are you thinking it would help with servicing the slave? It's a concentric style one so you'd still have to pull the engine or the torque tube to replace it. But I think they are pretty bullet proof so it shouldn't be a common failure.
For clutch inspections, I wonder if it could be done through the starter hole (you'd have to remove the starter, but that should be really easy).
#545
Well, hopefully since the Pontiac Solstice slave cylinder is self bleeding (closed system, no bleeder valve), servicing shouldn't be needed that often unless you manage to destroy a disk in a couple of days; in that case you might want to consider getting an automatic, or just stop doing red-line lauches at every stop light 😂
#547
Rainman
even if the BH isn't a 2-piece design, vt951's turbo layout will take a LOT of the work out of the 951 clutch job (dealing with the exhaust).
random data point but when i pulled the engine out of my NA car in july, i had the exhaust+trans on the ground and the torque tube pulled back out of the bellhousing in about an hour.
this is on stands on the floor of my garage, no lift or air tools or anything.
#548
#549
I really need to figure out a way to do this in CA . . . . if I can I am all in.
And yes, I wasn't sure if you had to slide the torque tube back to remove the hydraulic TOB . . . .
#550
With Black Friday/Cyber Monday coming up, is there any parts that we should be looking for on our own that we could maybe hunt for a deal on? Deals on car parts are kind of hit or miss but you never know.
From memory these are the items that are going to part of this kit as it's developed:
- Custom intake/SPA turbo exhaust manifold
- Engine mounts & 3 conversion parts from iAbed
- Bellhousing
- Clutch/flywheel setup (will this work for the TTRS 8 bolt forged crank? I thought there was a 6 bolt forged crank, maybe on early engines, but can't remember where in the thread it was mentioned)
That seems to cover most of the necessities to get the engine in in the car but if there is anything we will need to source ourselves it would be good to know. Otherwise it's just trying to find deals on the performance parts we want
- Bellhousing
#551
- Bellhousing
- Bellhousing
I designed the bellhousing around the following parts:
- SPEC aluminum flywheel from VW Golf Gen IV 1.8T 6-spd *** or TTRS if you are swapping in that 8-bolt crankshaft ***
- SPEC pressure plate from VW Golf Gen IV 1.8T 6-spd
- SPEC clutch disk from 944 turbo
- Starter for VW 02M 6-spd trans
- Pilot bearing from VW 02M 6-spd trans
- My custom designed pilot bearing adapter (due to difference in driveshaft stub length of 02M vs. 944)
- GM #24234308 or #24249824 release bearing
I sent SPEC an email asking about whether there is a version of the flywheel with 8 holes to fit the TTRS crank. I'll report back when I get a reply. I'm sure that if there isn't an existing product, they will make a new version with 8 holes.
***** Reply from SPEC: " Yes, we already make that flywheel with the TTRS pattern." *****
Maybe look for Black Friday deals on a turbo or engine management? I went with a Garrett G25-660 reverse rotation. If you go with the SPA turbo manifold, the reverse rotation turbo fits nice. I'll be making a little adapter to go from their t3 flange to the Garrett 2.5" v-band inlet.
#552
I am going to find the necessary little bits to connect things like the clutch ,,,, that is unless somebody is going to be making a conversion line . I found this little fitting , https://www.jegs.com/i/Earls/361/LS641001ERL/10002/-1 . I have also been looking at how to run the radiator coolant lines . Seems to me the best route would be the driver side . I`m going to look and see if I can find a suitable universal radiator through Griffins site . There are a lot of little things that will creep up in this swap . I`ll do my best to have an answer when the time comes .
#553
Finally some good news on the bellhousings... Holley confirmed they have pricing. They can't share it with me until it is approved up the chain, but at least it's moving. Something happened!
#554
