Did Porsche detuned the 951? Or it was fate? Article inside
#136
Having driven both the 944 and gt3, I actually prefer the way the gt3 handles. These are great cars and handle much better than their layout may have you think. I like the way the gt3 grips out of corners and its very precise turn in. I would rather track a gt3 over a 944 if I had the budget.
#137
How would 944 compare to gt3 if they would have sunk that much developing in to it as they did with 911 and tatra before that?
911 design is inferior to 944 as can be seen lately with Nissan GTR. I wonder how much development went in to GTR vs 911. Something like 1:10.000.000
#138
Basic Sponsor
#139
Maybe you haven't driven either design on the track - but here is a general tip;
Unstable can also mean quick to turn in, easy to rotate and generally responsive (in the right hands)
Stable can also mean slow to turn in, not responsive to trail braking and, in general, just too stable to be quick.
Now obviously I like the 944 chassis but to say that cars that have anything other than a 50/50 weight distribution are 'bad' is just not true. Unless you have driven a well set up 911 at the track you just are just recycling internet 'intelligence'.
BTW - the reason I say at the track is that you cannot get anywhere near the capabilities of a well set up 944 or 911 on the street. Ask anybody that has had the chance to drive around the track in a Porsche - they will all agree that the limit is not approachable on the street.
tino
#140
As for our cars...clearly I have a sickness but I'm not blind to their limitations. I'd love to swap out the trailing arm rear suspension for something from this Century. Well even late last would do, like Duke has.
I can't believe how much squat we got in the car, even with 1500lb rear springs.
The motion ratio works against us even though plenty of good results have been witnessed with our pre WW2 suspension design.
#141
#142
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
anyone...
1. what wishbone is Duke using?
2. can his setup be copied for less than 1 million dollars??
3. where to get: aftermarket/wrecked/burnt exotics/less exotics/ebay?
4. would a street car get any benefit from running a wishbone or is our pre-historic suspension good enough?
5. if I lived in Florida (year round), Texas or California, I'd definitely go stiffer front and back... but I drive on ****ty New England/New York roads and half-chewed-up interstate just about everyplace else... is there any benefit running only a stiffer rear suspension for the street?
#143
#145
anyone...
#146
anyone... 1. what wishbone is Duke using? 2. can his setup be copied for less than 1 million dollars?? 3. where to get: aftermarket/wrecked/burnt exotics/less exotics/ebay? 4. would a street car get any benefit from running a wishbone or is our pre-historic suspension good enough? 5. if I lived in Florida (year round), Texas or California, I'd definitely go stiffer front and back... but I drive on ****ty New England/New York roads and half-chewed-up interstate just about everyplace else... is there any benefit running only a stiffer rear suspension for the street?
2. I had a 996 on one lift, and a 944 on the other, and wondered the same. You're looking at some serious coin in fabrication labor.
3. Whats exotic about a 996 rear suspension? Any Porsche dismantler should have a few laying around.
4. You'd see no results on the street. As for the track, it would move you into the big boy category, where you'd need more than just a rear suspension to be competitive...
5. Just get a good coilover setup and you'll be happy, most spring rate set ups are too stiff for the street and too soft for the track, anyway...
#148
1. Duke grafted a 996 based rear suspension onto his car.
#149
Team Owner
thanks all.
and to the Aussies:
Fanning came up huge in the final seconds of 2 heats (like the bloody bastard basically has done all year) to bite
Kelly again for the title, in the most incredible/knurly pipe evarr. what a way to represent.... congrats.
recap;
http://www.surfline.com/video/contes...-finals_105022
and to the Aussies:
recap;
