X-post FS: Garage Cleaning Thread
I have quite a few miscellaneous items that I would like to clear out before moving. All prices are plus shipping, though I will offer a considerable incentive for those who buy multiple items! First one to pay by PayPal gets the item or items.
DO NOT QUOTE THIS WHOLE MESSAGE IN ANY REPLIES -- it's still fairly long and it will get confusing.
H&R 65mm wheel stud kit (10 studs and rotor screws): $60 SOLD
21mm hubcentric spacers (2): $40 SOLD
Steering shaft (like new): $20
![](https://farm6.staticflickr.com/5507/9432640152_e959aee040.jpg)
968 Steering wheel with airbag and clockspring (Click for additional photo of scratches on top of wheel): $50
![](https://farm8.staticflickr.com/7299/9429867635_6d0172a2d1.jpg)
Late cooling fan (like new, from Lart): $40
![](https://farm8.staticflickr.com/7313/9432640558_350745e1d8.jpg)
Under radiator rubber feet (used for one year): $5 SOLD
AC Delete alternator belt: $10
![](https://farm3.staticflickr.com/2818/9432640942_38597833f0.jpg)
Late ('87 and later) front wheel bearing and seal kit for one wheel: $15
![](https://farm4.staticflickr.com/3731/9432641230_60f0e563c4.jpg)
New door stop check: $10 SOLD
1 year old updated 968 caster blocks (replaced when I went to High Strung 44 arms): $40 SOLD
Working but ugly 968 starter: $60
![](https://farm8.staticflickr.com/7314/9432641862_28c409bf8b.jpg)
1 pound of 80A hardness liquid urethane for transmission mount mod: $20
![](https://farm3.staticflickr.com/2837/9429869237_ef791b5c78.jpg)
968 (and probably others) transmission output axle shaft seals (where the oil gets out around your axles -- set of 2): $10
![](https://farm8.staticflickr.com/7433/9429869377_9d7a3972ae.jpg)
Steering rack boot: $5 SOLD
Used aluminum lug nuts in acceptable condition (20): $10
![](https://farm6.staticflickr.com/5331/9432642634_87f4386d7b.jpg)
Left and right late turbo control arms with 2-year old ball joints (rebuild done by Blaszak Precision): $150 SOLD
Stock 968 torsion bars: $40
![](https://farm8.staticflickr.com/7360/9429869995_4dc0866f5f.jpg)
Lightly used (70% remaining) Hawk HPS pads for M030/928S4 black front calipers: $50
![](https://farm3.staticflickr.com/2820/9429870199_dd347f8978.jpg)
Complete set of good Pagid black street pads for non-M030 Turbo/S2/968 (8 pads = 4 wheels): $70 SOLD
Complete set of cheap (Textar?) street pads for non-M030 Turbo/S2/968 (8 pads = 4 wheels): $20
![](https://farm4.staticflickr.com/3797/9432643528_7b31d218b7.jpg)
Front brake scoops and backing plates: $20
![](https://farm3.staticflickr.com/2877/9432643698_8c0cc835a2.jpg)
New rear only braided brake lines: $20 SOLD
Spring plates (useable as-is with decent rubber) and Weltmeister bushings to replace that rubber: $100
![](https://farm3.staticflickr.com/2805/9432644224_6752a16c1b.jpg)
Lindsey Racing 2.25" spring hats for using coilover suspensions with standard strut mounts: $60 SOLD
Four late strut mounts with good bearings (some compression on all of them, to varying degrees): $50 for all four SOLD
Alternator with new voltage regulator, no pulley and noisy bearing, plus both required new bearings (in boxes): $40
![](https://farm3.staticflickr.com/2837/9429871899_7262520b26.jpg)
AC compressor and alternator mount: $30
![](https://farm8.staticflickr.com/7427/9429872129_4c4d504c36.jpg)
AC delete alternator snorkel: $20 SOLD
AFM from an '88 Turbo: $50 SOLD
968 (16v?) intake gasket: $10 SOLD
Exhaust flange gaskets (2): $10
![](https://farm3.staticflickr.com/2852/9432645816_517e2ac16b.jpg)
968 valve cover seal kit plus extra outer seal: $20 SOLD
Switches, relays and good DME temp sensor (fan relay will power fans, but could use repair): $20 SOLD
New Bosch 968 fuel pump, tank strainer and fuel filter: $100 SOLD
I think this is a 951 fuel filter (check to be sure, though!): $10
![](https://farm6.staticflickr.com/5450/9432646708_55168bcbd3.jpg)
Yellow Lamin-X covers for S2/Turbo fog lights: $10 SOLD
Stainless steel instrument rings: $20 SOLD
Turbo distributor cap: $15
![](https://farm8.staticflickr.com/7302/9432647226_bd9636b264.jpg)
968 distributor cap and wires: $75
![](https://farm6.staticflickr.com/5532/9432647530_fb2cb536bc.jpg)
1 CV joint kit (check part number to be sure it works for you): $70
![](https://farm6.staticflickr.com/5521/9432647782_2155d07814.jpg)
1 CV boot kit with grease: $15
![](https://farm6.staticflickr.com/5331/9429874905_344968cd2f.jpg)
Inner window scrapers: $15
![](https://farm6.staticflickr.com/5349/9432648050_59b3ac5a15.jpg)
Upper and lower balance shaft seals: $10 for both
![](https://farm8.staticflickr.com/7444/9432648318_2c3aa1d8b7.jpg)
16V valve seals (16): $10 SOLD
4x Brembo bleed screw caps (new): $10 SOLD
Very nice black Lloyd's matts, not losing foam: $100 SOLD
968 grille: $30
![](https://farm3.staticflickr.com/2839/9429876201_2bec00c18c.jpg)
1 used front non-M030 S2/Turbo/968 brake rotor (Zimmerman x-drilled e-coated): $40
![](https://farm3.staticflickr.com/2862/9432649610_d1691fc84e.jpg)
968 fuel rail cover powder coated silver: $50
968 grille: $30
![](https://farm6.staticflickr.com/5342/9429877323_5beac46483.jpg)
still might take them, need to see what kind of shape mine are in tomorrow. For now it is air tight, but I'm doubting they will seal again when I pull the exhaust apart to install my turbo.
Would like to purchase instument rings. Please PM PayPal info.
