My porsche 944 S2 16 valve turbo project
#241
Well I've got a little more done and some pictures to show you. I've been having a little trouble with the clutch slave cylinder and getting the right master cylinder.
These are pictures of the flywheel and twin plate clutch, plus slave cylinder.
![Name: DSC00213_zpsc0727023.jpg
Size: 91.5 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/1204506d1501313541-my-porsche-944-s2-16-valve-turbo-project-dsc00213_zpsc0727023.jpg)
![Name: DSC00215_zps21332ae6.jpg
Size: 91.7 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/1204507d1501313541-my-porsche-944-s2-16-valve-turbo-project-dsc00215_zps21332ae6.jpg)
![Name: DSC00218_zps9dcdda3a.jpg
Size: 39.3 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/1204508d1501313541-my-porsche-944-s2-16-valve-turbo-project-dsc00218_zps9dcdda3a.jpg)
The car is back together and mobile, the clutch works perfect.
One or two pictures of the engine compartment near to completion.
![Name: DSC00220_zps02d93621.jpg
Size: 105.3 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/1204509d1501313541-my-porsche-944-s2-16-valve-turbo-project-dsc00220_zps02d93621.jpg)
![Name: DSC00221_zps70bd0155.jpg
Size: 136.0 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/1204510d1501313541-my-porsche-944-s2-16-valve-turbo-project-dsc00221_zps70bd0155.jpg)
![Name: DSC00222_zps985075c7.jpg
Size: 121.8 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/1204511d1501313541-my-porsche-944-s2-16-valve-turbo-project-dsc00222_zps985075c7.jpg)
I have driven the car up and down our road and it seems good and responsive, I have got a boost map to sort and check fuel map. Looking good though, well pleased.
#244
I'm going to be using it on the road. The clutch is from a TVR. It is a twin eight and a half inch organic clutch. Feels good, the only downside is a slight rattle from the plates when engaged.
#245
Cerbera clutch I would guess? Interesting... I have to look into this.
No clearance issue at all after grinding/apdating the bellhousing then?
I have always wanted a Cerb, well before I got into 944s, would be fun to adapt this clutch setup on my car.
Edit : just seen the Tuscan mention. Is it the same clutch for both 3.6 and 4.0 engines?
#251
very nice!
#252
Sorry for the late reply. I ended up using the Garrett Stage 5 turbo with the T350 wheel, works very well except the back pressure is a little higher than I would have liked at high rev's. It comes on boost well pulls hard and I'm mainly using it on the road.
Cheers Tim
Cheers Tim
