Official V8 Registry.
#94
#95
Would be great if you guys could also post what kind of brake setups you are running, be it manual, dual master (and what sizes your using), pedal box, hydroboost (BMW, Ford) or electric booster. Also your impressions of pedal feel on the street and track.
I am going to try the Ford hydroboost setup with my car, i have some concerns about pedal feel though. Knowing me ill probably end up changing my mind a few times and end up installing a very expensive Tilton pedal box due to how **** i am .
#96
I found this interesting setup on a race car for sale on Ebay, the brake servos look like remote brake servos found on early Minis (1 servo per brake circuit).
I also found some information at the below link.
http://www.heystee-automotive.com/pa...brks/servo.htm
#97
I have dual master cylinder using a 5/8F and .70R through a tilton balance bar set 55% to the front, early solid pedal drilled just under an inch higher for the pivot point on stock '87 turbo brakes. I daily drive my car and the pedal feel is good. It doesn't take much pressure at all to stop in normal situations. The braking is very progressive when you need to stop quicker.
#98
I studied the pictures in that auction as well. It's an interesting setup that I pursued for a bit in my build. Here's another link to how they work:
http://www.mgb-stuff.org.uk/servo.htm
But I've found my Tilton pedal box w/ dual masters to work well.
Rich
Rich
#100
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
well,
bidding was very aggressive on this engine in the final hour.
and with about 12 seconds left, i submitted a bid of $4,200..... and then, nothing....
finally the pop up came up and i clicked "Confirm".
be damned if there wasn't but 1 second left on the clock at this moment....
and....
and....
#101
well,
and....
and....
SAWEET deal. Congratulations.
#104
Here are my 968 LS1 Project
94 968 with 2002 C5 LS1
TR224 cam Comp 918 and TSP push rod
Most of swap kit were source from RH
Custom True dual with high flow cat
Work none stop even at Xmas even GT2 style Fender flare and new Wheels
hope to finish every thing before new year
Almost finish the exterior... Still need to put rear bumper back
pic was taking 3 am Xmas even
next will be suspension
