3.0l 16v turbo rod bearing failure
#31
All I can say is I hope whatever resolution you decide is that I want it to be a success.
There is an obvious inherent flaw in the oiling systems. I do think that the smaller bearings (also modern bearing materials) help to maintain integrity. The surface area
il volume ratio is better.
Couple that with lighter parts it would seem to also be a benefit to bearing load.
I am not the only one who has done this. Henk's racing engine uses the same design.
The crank may have a substantial hardness from the factory, however, in these cases it doesn't seem to be helping out much.
After grinding you can have them nitrided and bring the surface hardness back up. Maybe not as deep but enough for a solid bearing surface.
I do my stuff inexpensively, but I will say that regardless of budget, I would use the smaller bearings.
Again this is not new tech, MM, along with other engine builders have been doing it for decades.
Not trying to argue, just relaying what I've learned through the process.
Duke, if you decided to scap your parts.. I would be interested
although shipping would be prohibitive.
![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
#33
Offset grinding decreases the overlap between the main and big end journals and reduces the bearing area, having said that the crank is a very strong item to start with so it seems to be still all good.
#37
Castrol Edge 10w60 is pretty much the top tier of oil and the engine had been running for less then a seson so in my case there wasn't really any more I could have done to prevent this.
#39
Regarding the stroker cranks. I'm sure it can be done correctly, but it's not really an apples to apples comparison with street cars and race cars than pull consistantly over 1.4G's cornering.
I'm sure this engine would have survived for tenth's of thousands of kilometers on the street.
#40
I had a quick look at the spec on the Castrol Edge and I dont think it's a triple ester PAO blend, that and the lowish price makes me think you could do better.
#41
Let's not turn this into another oil thread.. The Castrol 10w60 Edge is a decent oil. But nevermind, you're theorizing a bit too much, this failure was not related to the oil.
#43
I can assure you you may change your view regarding race quality.
PM coming in the next couple hours.
#45
