M-Tune with E85 vs Pump Gas
So... Several people have their M-Tune installed for a while now, surely someone has done a comparison dyno run. Right? I'd love to see some numbers...
I am curious to know what 93 octane at 18 PSI versus E85 at 21 PSI looks like on the same car, same dyno, and similar conditions. Who's got graphs they can post?
At a minimum, I'm curious to know what fuel mileage does with the change. Typically E85 is 15-20% less fuel efficient compared to gas, I'm curious to know of that holds true in these cars with M-Tune.
Are you running a WB? I'm curious to know what my AFR will do when I change. I've read the discussions and it sounds like I shouldn't see much of a difference and that 12.5 is still the maximum safe target.
Small Business Partner
The first tank full of E85 will likely be a little rich - this is due to the leftover gas in the tank mixing.
And yes, your target AFR will be similar to what you are seeing now.
I just wish my gas gauge wad accurate or that my odometer worked... I'll be shooting in the dark regarding fuel level when I switch over.
I have been using my M-tune with E85 on the track for the last month. AFR at Willow Springs at 140mph was 11.5 in 5th gear @ max. boost 20 PSI. Performance was awesome. I will be upgrade my turbo from K26/8 to K27/8 before next event.
My question is, can these 23+ year old engines really handle E85? The stuff can't even be transported in the same pipes as normal gas due to corrosion. I wonder what that does to the internals of an engine?
Personally I found 106 octane pretty close to me. Its a lot more expensive, but since its not my daily driver the cost won't be that bad. I won't use E85 in my car.
Lolololololololololololololol......
Hmmm how many years has it been now? Let me think, over fifteen years running ethanol and over seven years running e85 in my DD and stored 944's. Got to love the enthusiasm...
I've been on e85 for ~a year now. I know I'm just an NA car, but the principle of it is the same.
With the tune I have now, I get between 18 and 20MPG in the city. On the best highway run I made, I got ~22mpg. It wasn't a full tank of highway, but 75% of it was. FWIW, I could get 29 on the highway, with the AC on, on gasoline.
I think I can do better too. I'm not the most proficient tuner in the world, so I think as I get more practice, my mpg's will go up a little more.
I'm having flashbacks..I should go look look on pelican and see how long ago it was I was having these discussions.
I truly thought everyone was over this...... I need to just avoid this...but I can't. I'm not sure how many years or miles it will take for this thinking to go away. One thing I know for certain is that my engines have lived a hell of a lot longer due to E85. Very certain!!!
As for power, I have wittnessed a pretty well tuned car run in the turbos efficiency range at 18 psi up here and went 104ish. I have ran 115-118 at 22-23 psi. So for _REAL HP_ not dyno id say around 310-320hp on pump and 400 hp on e85. At sea level the hp would be higher. But this is a direct comparison for cars set up to run these two boost levels efficiently.
