Patrick's build thread. (IT RUNS!)
#948
Thanks Sid. Hey I'm back now. Do you want me to try and get some sort of contact with those guys down here still?
#950
Freedom Enthusiast
Are you selling off parts of your car?
or are people just using pics of your car whenever they want?
http://www.ebay.com/itm/Porsche-944-...d72bbc&vxp=mtr
#951
That's from the fabricator that actually made some of the body parts as shown in the pics. So all good, but thanks for looking out for me. :-)
#954
Just adding a bit more on this thread so I can direct people to it who are asking about certain aspects. Rather than me post pics in other's threads that is.
So here is the new 'sealing system' we put into place a few months ago. We had got to the point of having to replace the Cometic head gaskets after every meeting. We also did a little bit of minor damage to some bores by having coolant sitting in the cylinders between taking the head off to replace the headgasket. Minor 'rust rings' I guess you'd term them. The motor is coming apart as I write this and the ring while tactile to the 'thumbnail test' looks like it will respond to a light honing and we can reassemble it with new rings and same pistons. Hope so anyway. A new larger 8v head is in the wings too. More of that later.
So we decided to use a local company to 'O' ring the liners and make up some Beru rings that would sit in the groove. We also had another local company make up a Copper head gasket. So far so good, we've run it a few times on the dyno at 25psi and on the track under sustained boost and we didn't lose any coolant. Really nice when something works straight up. Now that the motor is being pulled down we have found that both the rings and the gasket are in great order and we will be reusing them when we have the new crank and head available.
#956
PLAN Q:
Pulled rest of motor down to find this. Now is Toast. Yay! Whatever led to the failure had a resounding success through the whole motor. Not sure of cause but plenty of symptoms. Pity....
Neeeexxxxt!!!!
Neeeexxxxt!!!!
#958
Professional Hoon
I'm going to take a wild guess at this.
Those out of round tyres would have contributed to something, but i think the try sump pulley may have been to tight? causing some flex on the crank causing the crank bolt to loosen which caused the balance shaft main pulley to spin freely and damage the keyway all the way around which causes the engine to be out of balance badly which:
A) make the car shave violently
and
b) cause bolts to back out.
and
#959
Is that exactly as found, no other bolts undone other than the sump?
Wow. If so, lots happening with the cradle.
Needs some expert interpretation. I still have suspicions about harmonics.
Good luck!
Cheers,
Mike
Good luck!
Cheers,
Mike
#960
and
and
Now we will just have to bring forward the 16v motor. All the same, shame to lose this one so catastrophically. The interesting fact is that the two pulleys failed at almost the identical part on the track. Higher loads on motors are sometimes caused during backoff rather than full load. This might be one of them as the place on the track was through a fast turn following the main straight.
