Can you put a bov on a 951??
Old 05-16-2002, 04:28 AM
DasWeis951
DasWeis951's Avatar
Post Can you put a bov on a 951??
This may be a dumb wuestion, cause I dont know about the 951 engine, but does it come with a BOV, or a diverter valve. I guess what i'm asking is is it a closed loop or open loop system???
I want that psssssst sound, but i'm not sure if I can put one on it.
Old 05-16-2002, 04:45 AM
TurboMan
TurboMan's Avatar
Post
I'm not quite sure what you mean by open or closed loop, but yes, the 951 comes qith a bov from factory. If you look at the front right corner of the engine bay, it is that small black cylinder thing with a small vacuum hose on top.
The reason you don't hear the pssssst-sound is because it vents the air back to the turbo intake instead of straight to the atmosphere.
Old 05-16-2002, 07:13 AM
si
si's Avatar
Post
that psst blow-off sound is for rice-racers ONLY, you DONT want one.
si
91 951s, silver, 17in cups, chips, LBE, Mint.
Old 05-16-2002, 09:53 AM
Duke
Duke's Avatar
Post
[quote]Originally posted by TurboMan:
<strong>The reason you don't hear the pssssst-sound is because it vents the air back to the turbo intake instead of straight to the atmosphere.</strong><hr></blockquote>
That design is called closed loop.
Old 05-16-2002, 10:45 AM
Russ Murphy
Russ Murphy's Avatar
Post
For "rice-racers" only? Really? I guess I've joined their ranks, as my compresor bypass/BOV vents to the atmoshpere and sounds BAD-@SS too! Si, you'd hear it (and agree that it's bad-@ss) if my car wasn't flying by you so fast.
[quote] I want that psssssst sound, but i'm not sure if I can put one on it. <hr></blockquote>
You can if you go to a MAP based engine management system, but not with your stock efi.
Old 05-16-2002, 12:22 PM
rage2
rage2's Avatar
Post
[quote]Originally posted by si:
<strong>that psst blow-off sound is for rice-racers ONLY, you DONT want one.</strong><hr></blockquote>
I must be pretty rice too, along with the WRC rally cars =).
Not sure if there's really much advantages to blowing off into the atmosphere vs routing back into the system, but for MAP sensor'd cars, the BOV/Cycling Valve sits in front of the MAP sensor so the air isn't measured yet, and you can vent it anywhere you please.
I know when I upgraded from the cycling valve to a BOV, the boost kicked in much harder.
Old 05-16-2002, 12:43 PM
DasWeis951
DasWeis951's Avatar
Post
how do I know if its a MAP system? did certain year 951 come with non MAP sensors?
I really wanna put one on, yea it does sound bad ****....
its a 87
Old 05-16-2002, 12:53 PM
David Floyd
David Floyd's Avatar
Post
I have the Turbonetics Monster Blow off running back into the MAF and You can hear this baby talk.
Not rice in my book when it is a working piece.
Now if you put on one of those electronic sound devices to make someone believe you are turbocharged then that's rice.
<img src="graemlins/burnout.gif" border="0" alt="[burnout]" /> <img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
Old 05-16-2002, 01:56 PM
Sloth
Sloth's Avatar
Post
Turbonetics BOV on a stock tube.
Old 05-16-2002, 01:57 PM
Silverbullet951
Silverbullet951's Avatar
Post
[quote]Originally posted by DasWeis951:
<strong>how do I know if its a MAP system? did certain year 951 come with non MAP sensors?
its a 87</strong><hr></blockquote>
every 951 came with a AFM, not a MAP. If you changed to a MAP, then you would be able to get that psssst sound.
Old 05-16-2002, 04:34 PM
Luke
Luke's Avatar
Post
[quote]Originally posted by Russ Murphy:
<strong>You can if you go to a MAP based engine management system, but not with your stock efi.</strong><hr></blockquote>
Why can't you Blow into the atmo. with a unit that has a stiffer spring?
As long as you aren't leaking, right? (so there is no "counted" flow leaking off)
Old 05-16-2002, 06:27 PM
DasWeis951
DasWeis951's Avatar
Post
ok so ow do I change it to map??
Old 05-16-2002, 06:35 PM
Silverbullet951
Post
<strong>ok so ow do I change it to map??</strong><hr></blockquote>
<a href="http://www.sdsefi.com/" target="_blank">SDS EFi</a>
Old 05-16-2002, 07:44 PM
toddk911
Drive-by provocation guy
toddk911's Avatar
Post
How much hp/tq differences are there o te BOV as opposed to a cycling valve?
Old 05-17-2002, 01:36 AM
Seattle944t
Seattle944t's Avatar
Post
[quote]Originally posted by Luke:
<strong>
As long as you aren't leaking, right? (so there is no "counted" flow leaking off)</strong><hr></blockquote>
If you vent to atmosphere you are leaking, since the BOV (recirculation in this case) is after the meter. It's all 'counted flow' at that point, so you'll end up with a very over rich mixture between shifts (depending on the amount of boost that was being generated). That will only hurt performance and engine response between shifts.
Quick Reply: Can you put a bov on a 951??
