new side mirror gasket problem
Is there a trick to getting these gaskets to fit? I've tried soaking them in hot water and stretching the hell of out them... but the shape just doesn't look right. Even when I can get it to stretch around the mirror base, the gasket won't stay put unless I'm holding it with 3 hands, which makes installing the mirror near impossible.
Karl,
I used a bit of adhesive to help hold in place, yet even still had to 'work it' around as I assembled.
I'm with you on the shape doesn't seem quite large enough/correct. PITA should be its part number. Good Luck with it.
Karl, try the early (pre-85.5) gasket. I went thru some old threads, and it looks like its possible that some 85.5 had the early base, and the gasket is more of a rectangle than yours appears. Look at the pics on Pelicans site and you'll see what I'm thinking.
One trick for installing them (and I agree with the others, I believe you have the wrong gasket) is to heat them up with a heat gun so that they are pliable. It makes them a lot easier to install. Hopefully it goes without saying that you want to just get them warmed up, not melted.
I bought new gaskets for a 86> 944 and had the same problem. I have a 1986 951 and with the old type gaskets it worked just fine. The shape is slightly differerent.
