What do i need for a 3L turbo build?
Professional Hoon
Okay so i've been speaking about mods about my car for a while. new turbo, exhaust ect ect... and it goes on. Just never get around doing anything because of time factor. And now I'm thinking of going down the 3L road...
So what would i need for the build apart from:
new pistons (forged ofcorse)
Darton MID sleves xxxx MM
Bearings
crank shaft??? or stock one is fine?
what else??
then supporting mods would be
turbo probably gt30 or gt35 with an 82 A/R
custom 4" exhaust
custom downpipe
injectors, FPR, fuel pump
intercooler,
TiAL 38mm
intake
EMS... wolf v500 ?
Cams?? or stock is good?
ported head.... are lindsey racing heads worth the price? their stage 3 4 5 or 5+ ?
it seems like theres things missing?
Thanks guys
Bearings
what else??
custom 4" exhaust
custom downpipe
intercooler,
TiAL 38mm
intake
EMS... wolf v500 ?
Thanks guys
You would need the 3.0L crankshaft as well. It has an 88 mm stroke.
Check out these builds...
https://rennlist.com/forums/944-turb...-registry.html
Professional Hoon
crankshaft? would there be a power or torque difference?
15-20k ?
https://rennlist.com/forums/944-turb...bo-thread.html
https://rennlist.com/forums/944-turb...r-8v-head.html
https://rennlist.com/forums/944-turb...ct-2010-a.html
Ah, yeah...
I posted this list a while back.....
Block
Block machine work
Pistons/rings/pins
Rods
Rod bearings
Main bearings
Bottom end gasket kit
Oil stone for pump surface
Various sealants (Assembly lube, loctites, etc.)
Head (951 exhaust, 2.7 intake)
Head machining
Intake port matching
Thermal coatings (2.7 head)
Head gasket set
Balance Shaft bearings
Rollers, t-belt, b/s belt
Waterpump
Thermostat (2) and clip/o-rings
Re-using old hoses?
Oil pump (used s/b ok)
Head studs/nuts
Exhaust seals
Cam (optional)
Many miscellaneous seals (aluminum rings, o-rings, etc.)
Replacement fasteners (they break)
Turbocharger (for 3L)
Engine Management (Chips, VR board, s/o, etc.)
MAF or MAP
Flywheel and PP machining
Clutch disk
Flywheel/PP bolts
Throwout bearing and guide tube
Tools (ring compressor, bolt stretch mic, etc)
Accessory belts, hoses, plugs, wires, etc. (maintenance items)
Oil
Coolant
P/S fluid
R12 Refill
Wastegate?
Boost controller?
Bypass valve?
Block
Block machine work
Pistons/rings/pins
Rods
Rod bearings
Main bearings
Head machining
Head gasket set
Waterpump
Re-using old hoses?
Head studs/nuts
Exhaust seals
Cam (optional)
MAF or MAP
Clutch disk
Flywheel/PP bolts
Oil
Coolant
P/S fluid
R12 Refill
Wastegate?
Boost controller?
Bypass valve?
Block
Block machine work
Pistons/rings/pins
Rods
Rod bearings
Main bearings
Head machining
Head gasket set
Waterpump
Re-using old hoses?
Head studs/nuts
Exhaust seals
Cam (optional)
MAF or MAP
Clutch disk
Flywheel/PP bolts
Oil
Coolant
P/S fluid
R12 Refill
Wastegate?
Boost controller?
Bypass valve?
Block
Block machine work
Pistons/rings/pins
Rods
Rod bearings
Main bearings
Head machining
Head gasket set
Waterpump
Re-using old hoses?
Head studs/nuts
Exhaust seals
Cam (optional)
MAF or MAP
Clutch disk
Flywheel/PP bolts
Oil
Coolant
P/S fluid
R12 Refill
Wastegate?
Boost controller?
Bypass valve?
Besides, perhaps since those old threads were created new information has surfaced that has not yet been shared! Nope I don't have any... but someone might.
