Project 951 young man's first Porsche
Old 02-07-2011, 09:35 AM
  #196
Olli Snellman
Olli Snellman's Avatar
Since we are changing Motronic to Tatech we think possibilities to make installation a little bit easier. 968 & S2 use newer version of Motronic which has a bit different triggering than 944 & 951. A friend of mine will fabricate a 951 compatible flywheel with "modern style S2/968" 60-2 gears, so there will only be one crank sensor and we also get rid of the speed sensor. Might be possible that we will install another 968 & S2 style sensor on cam wheel. Another friend already made necessary CAD drawings and we are more or less ready to produce 951 60-2 flywheel for our project.
Finally got some new parts for front control arms
Similar bushings for rear control arms are on their way
Old 02-12-2011, 03:58 AM
  #197
Olli Snellman
Had a design session with Antti yesterday. We would like to have a powersteering reservoir which does not leak like oem system does. Found this design from a BMW-forum. It's nice, but does not eliminate the major problem. We plan to use AN-style fittings which are superior compared to oem design. We toyed with an idea to produce similar style bow and oil catch tank made also form billet with AN-fittings.
Tank from BMW-forum:
Bow we have uses already a little bit same design than that PS-reservoir
Few pictures from Antti's place.
Installing a Tiptronic unit under 968
It's almost there My eldest son Lauri making some final installations
Antti tig welding some parts to modified 997 GT2 intake for 996 Turbo engine
Special tool for 951 rear hubs. 500nm is quite nice torque when you have to un-bolt the nuts
Old 02-12-2011, 09:18 AM
  #198
black944 turbo
black944 turbo's Avatar
I love that power steering tank, Very nice setup.
Old 02-12-2011, 10:56 AM
  #199
Olli Snellman
Actually that BMW tank is not so nice.It have two major problems in it's design.
Old 02-12-2011, 11:03 AM
  #200
JohnKoaWood
JohnKoaWood's Avatar
Olli, you do know they do offer pipes shorter than 15 feet long?
Having just completed my rear wheel bearing replacement, I used 3/4 inch drive beaker bar / extension / socket, and put a 4 foot pipe on the breaker bar... worked like a charm! But then my trailing arms were still on the car... I like the adapter for holding the hub with the arms off the car... some very nice parts pictured, and nice tooling being used!
Old 02-12-2011, 11:07 AM
  #201
Olli Snellman
John, we do not work at the gym, so we must use looong pipes
Old 02-12-2011, 11:43 AM
  #202
NEVA951
NEVA951's Avatar
I am stronger than Antti and Olli`s son, so this is fine for me
Old 02-12-2011, 02:05 PM
  #203
Crazy Eddie
Crazy Eddie's Avatar
I bet I can guess one of them ...?
They don't have filter inside like the stock one has at the bottom of the tank.....
My second guess, they don't have a built in dip stick in the cap to measuer the fluid level?
Best regards
Ed
Old 02-12-2011, 02:32 PM
  #204
Olli Snellman
You might be right Ed. Personally i don't like that big O-ring and oem-style fittings. Both of these will eventually start to leak.
Old 03-23-2011, 04:54 AM
  #205
Olli Snellman
While i was putting Jaybird Hockey tape on some wires, son painted his burgundy dash and some other parts to black.
First he washed the parts and used some silicon remove stuff
Then fresh black paint
Painted parts looks in live like factory new
Next items to be painted are 968 door panels, which are now blue
Old 03-23-2011, 09:16 PM
  #206
951Doc
951Doc's Avatar
Wow, nice picture of a girl in black boots and white hot pants!
951Doc
Old 03-23-2011, 09:25 PM
  #207
Scott H
Scott H's Avatar
That painted dash looks killer. I used something similar to get my rear hatch carpet dyed back to black (PO spilled some chlorine or something) and I couldn't believe how well it looked for a $5 can of paint.
951Doc
I had to go back and look to see what you were talking about... indeed. I bet if we had ads like that in America our newspapers wouldn't all be going bankrupt!
Old 03-23-2011, 10:20 PM
  #208
Crazy Eddie
951Doc
I'm like,.... black boots and white hot pants, WHERE !!!
Then I saw the newspaper ...
From what I have hear, they all look like that over there
Yea I would like to know what spray paint he used Olli... Looks great
Scott, I agree but it would take a lot more to to bring our leftist rags here back to life ... One would be to print the truth once in a while ...
But the girl in hot pants would be a great start
Regards
Ed
Old 03-24-2011, 03:11 AM
  #209
Olli Snellman
You guys surely can pick up the most important things from the pics
We put that page as a teaser and wondered how many of you will make a comment
OK, less important issues; paint we used is normal VHT vinyl paint. I tested it first time in the late '70's and have been used it ever since. Great product
Old 03-24-2011, 03:31 AM
  #210
Crazy Eddie
Priorities ...
Wow I didn't know VHT made that type of paint ..?
I have used their paints extensively I'll have to look for that one
Ed
Quick Reply: Project 951 young man's first Porsche
