For Sale: Dry sump
Complete plug&play 3 stage dry sump.
3 stage pump, 3 gallon tank.
-16 in -12 return.
100% complete including ALL plates, lines, AOS delete, vent, proper pressure set, tank level, factory oil pump delete provisions, HP6 filter size, instructions, etc.
System uses FACTORY OIL PRESSURE SENDER, so as to use the factory cluster - undisturbed.
Filter system and factory pressure sender are visible in this current avatar.
One ONLY.
$3,000.00
Less than 100 hours.
If interested, contact me at:
artisticmason@comcast.net
I have a few other unique and run-in parts you may also be interested in.
-Jim
-16 in -12 return.
One ONLY.
$3,000.00
-Jim
Raising money? Be a double win. Extra hp and ultimate safety.
Also selling the reverse-flow intake, pipes, 3.5 inch TB, plug/play necessary throttle cable, intercooler (requires sheetmetal modification), tee-bolts and all associated silicone plumbing.
This was the intake setup on the 600 WHP runs.
$1,600
I can seperate, if you want.
