Hmmm, build progress...
Old 04-16-2010, 01:26 PM
  #61
gregeast
gregeast's Avatar
Is it running???
Old 04-16-2010, 04:47 PM
  #62
docwyte
docwyte's Avatar
Turbo has a leaky water pipe. That's now at the fabricator getting fixed.
Old 04-16-2010, 05:12 PM
  #63
LFA951
LFA951's Avatar
Very nice work!
Old 04-19-2010, 06:04 PM
  #64
docwyte
docwyte's Avatar
Car is running! Seems like it's having a little issue with backfiring, here's what the note the mechanic sent me. Any ideas?
"Car is running. Idles decently but it does not accept quickly opened throttle w/o backfiring.
Chip board is set all on except #3.
Map isn't hooked up yet. Not sure what effect that has other than boost control."
Old 04-19-2010, 06:13 PM
  #65
fast951
fast951's Avatar
Josh,
Replied to your email. I'll post here as well...
If you are running a V-FLEX image, the MAP sensor MUST be connected to the DME. When running V-FLEX, the DME will detect a disconnected MAP sensor (or pinched line) and will trigger fail-safe by killing timing. Not sure if this is what you are experiencing.
With V-FLEX, the MAP sensor is used to alter ignition timing (it can also be used for boost control). The main function is ignition!
If it's backfiring from the exhaust, it's rich!..
The followings should be checked:
- fuel pressure to 3bar,
- FQS should be set correctly
- TPS is functioning correctly
- O2 sensor is operational
- If you have the PB in place, make sure no "funny" values in there.
John
Email
www.vitesseracing.com
Old 04-19-2010, 06:27 PM
  #66
docwyte
docwyte's Avatar
Got it. Thought it had something to do with the vflex and MAP sensor and I sent those suspicions to the shop. Thanks for the support and I'll forward your reply!
edit: Shop just replied, car runs well when not on the vflex map, so you're right on the money John. The MAP sensor needs to be installed and all should be good!
Old 04-19-2010, 06:50 PM
  #67
docwyte
docwyte's Avatar
Taking it to get smogged tomorrow morning!
Old 04-22-2010, 12:22 AM
  #68
88951er
88951er's Avatar
Exciting times Doc! Sounds like a great setup. Congrats!
Old 04-22-2010, 02:52 AM
  #69
alxdgr8
alxdgr8's Avatar
Where are the engine bay pics?
Old 04-22-2010, 10:46 AM
  #70
docwyte
docwyte's Avatar
Getting the car today. I'll post more once I lay my eyes on it.
Old 05-07-2010, 07:48 PM
  #71
docwyte
docwyte's Avatar
Well, had to pull the car out of the other mechanic's shop. It didn't pass smog and he didn't finish the installation or trouble shoot what had already been done.
I spent some time doing some small projects, than sent it over to a different shop last week to get finished.
So far they've gotten the boost solenoid, MAP sensor and SMT6 installed, along with my gauges. They had to replace the headlite relay, as the lites were going nuts.
There's a charging issue somewhere, as the alternator charges here and there. There are also some vacuum leaks to address. These are probably causing some of the running issues...
Those are next up, then getting it past smog, then setting the boost maps and tuning the fuel.
Hopefully have it back up and running and completely finished next week.
Old 05-07-2010, 08:15 PM
  #72
MM951
MM951's Avatar
Shame you have had an ordeal with the car, but it should kick *** soon enough
Old 05-08-2010, 01:24 AM
  #73
Darwantae951
Darwantae951's Avatar
+1, I remember when the car was advertised for sale, and the seller said it was good to go...doesn't help that his PPI was ****, too...
Hope you get her sorted soon Doc!
Old 05-08-2010, 12:11 PM
  #74
docwyte
docwyte's Avatar
Yeah, good to go with a bunch of maintenance! Some of things I've done were preventative, but the oil pan gasket, motor mounts, charging issue and timing belt were immediate needs that HAD to be done right away.
I still can't believe the PPI missed the oil pan gasket and timing belt...
Old 05-12-2010, 11:10 AM
  #75
docwyte
docwyte's Avatar
Update! Car is running well, the intake manifold wasn't on tightly enough, causing all sorts of idle and A/F issues.
MAP sensor, boost solenoid, gauges, boost map switching switch (extra mirror control switch) installed.
Car should get A/F and boost maps set and tuned, AC charged, charging issue fixed and smogged, then it'll be done!
Quick Reply: Hmmm, build progress...
