View Poll Results: What's your HP level
Voters: 131. You may not vote on this poll
Poll. What's your HP range?
#106
Drive-by provocation guy
i.e. regardless of how rich, just too much timing for 15+psi
#107
Rogue is correct. The 3rd and 4th gear runs will come out within a few hp of each other (for example, on my car approx. 300rwhp, 3rd or 4th came to within 10hp of each other). I use to have a mustang 500SE dyno at the shop.
As far as making hp numbers, all you need to do on a mustang to make high (or low) numbers is change the weight of the dyno in the parameter settings. Takes 3 seconds. Boom 600hp out of a stock 2.5L NA Instant bragging rights.
#109
Now, just a breakdown of those numbers at what boost and then we would know the most effecient setups.
I.e the highest hp @ lowest boost would be the most effecient/effective set up.
#110
Dynos are fantastic for tuning and troubleshooting problems that you can't reproduce on the street easily.....being able to do hp runs is just a fun feature of each dyno, but you should interpret that number as an approximation.
#111
Geez ...if we can throw any old thought and car out here...... f' it where is the option for 4000hp (I've done that before).
Hell just 3 weeks ago I made 1800 hp with a thumper 106 turbod SBC.
FYI I'm under the 400-450 range (for the 951).
I really don't think it's cool that people are just throwing numbers out w/o doing ****.....
#112
Stock 944 turbo - 220hp
exhaust - 25hp
boost enhancer - 30hp
K&N air filter - 15hp
"stage 2" chips - 50hp
platinum plugs - 10hp
adjustable fuel pressure reg - 25hp
Total - 385hp at the crank or about 355 at the wheels
#114
Basic Sponsor
#116
There has been too many varied hp reads with similar mods to give much creedence to this poll. We've seen variances of +/- 100whp with almost identical mods throughout the world. I still maintain that US figures seem higher than the ROW and sure that some of this could be down to superior tuning but I don't think all of it is...sooooo.....Anyway I hope to add to this silly poll soon and this will be off an engine dyno. Saying that, how much load is dialed into this dyno I don't know. Guess it doesn't matter. It's only a number. Still got to put the rubber down on the track...that's where it counts!!!
