Adapting 89 Engine Harness to 87/86 Car
I have just about re-finished re-shelling my car, in preperation for Hallett in a couple of weeks.
The shell is an 87, the engine harness is an 89.
I am trying to get the Tach and boost gage to work and its driving me nuts.
The schematic from an 86 car seems to match my car harness its a 4 pin rectangular plug. with pins 1-4 as Red/white, Black/green, Black/grey, white.
The 89 harness is an 8 pin. 1-4 as follows
White/green, Green/black, Yellow/green, Brown.
I have an 87 schematic but not an 89. If I compare the 86 and 87 wiring diagrams, both show pins 1 and 2 are supposed to be the tach and 3 4 the boost gage.
So the pin configuration appears to be the same and I should be able to get it to work, but nothing I try works.
If I connect just the pins 1 and 2 the car will not run, doesn't matter which way around I have them. Likewise I can't get anything out of the boost gage.
I don't care about the boost gage as I have an aftermarket, but its going to be tough to race without a Tach.
Any help greatly appreciated.
1. DME #11 - HSA
2. DME #21 - RPM to Tach
3. KLR #5 - Boost signal to Gage
4. C50 (MP) - Boost gage grounding
5. -- -
6. -- -
7. Diagnostic - TCS/TC
8. Oil level warning switch - Oil level warning light
Hope this helps.
Pete
5. -- -
6. -- -
Hope this helps.
Pete
Thanks Pete,
That matches my understanding but its just not working. I am wondering if the 4 pin plug I found is not the DME plug? The 4 pin plug matches the 86 wiring diagram, even though its an 87 car. I guess I'll have to trace the wires to the instrument cluster and confirm I am on the right plug.
Richard
Richard
86 instrument plug
1 WS/GN DME11 White/Green
2 GN/SW DME21 Green/black
3 RT/WS KLR5 Red/White
4 RT/GN Ground? Red/Green
87 instrument plug
3 BL KLR5 Blue
If your car is an 87, someone cut up the harness to try to connect to an 86 engine harness?
If you have pins 1-4 as Red/white, Black/green, Black/grey, brown, the wires just aren't right....
87 instrument plug
3 BL KLR5 Blue
In WSM Vol 6 -turbo at page 28-14 the DME pin #11 it comes from is "4-pole separation point terminal 1 ( consumption indicator )" !!
