Transmission problems
Monkeys Removed by Request
I totally jixned myself. I was talking about how good the car is running and how solid it feels then......BAM.
I'm hearing all kinds of noise in each gear. Reverse is quiet. When im sitting at idle I can hear all the mechanical clanking then I depress the clutch and it all go's away. Moving forward in ANY gear brings all sorts of nose but, the car does move and go'. Infact I drove it up on the flatbed and off again last night.
I guess its going back to Advanced Automotive on monday for tranny
This means no fest for me, no anything really(I was about to order side skirts, mirrors, door handles, and a splitter to go with the TRS wing). I just spent 2k fixing a few other bits on the car(suspension). Whats a rebuild on one of these go for?
Also is there anything I could check today under the car to see if its by any chance something else?
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
John, Sorry to hear that you are having issues. Are you hearing the Torque Tube bearings? Or the transmission?
If it's the transmission, before rebuilding, you might find a good transaxle with a known history with LSD. If you decide to rebuild the transaxle, make sure it's done by someone who actually has experience with these units.
It's pretty hard to break a Pinion in my experience, It's more likely or rather hopefully a cheaper weaker link in the chain of 951 weakness. I know your pain, my car had just gotten back together with significantly more power and I went to hard launch and never made it completely into first, it popped out of gear and made impressive crack poof and I thought I had blown the trans and had to get towed but in the end it was the cage for the bearings for the axle.
IIRC my rebuild was approx $3400 CAD
If its not the tranny what do these other parts cost to fix?
i don't want to hijack the thread but i wanted to ask ... do you guys shift into 1st on your downshift ? i just go from 2nd to neutral at around 2000 rpm when i come to a stop. Also do you shift from 3 to 2 quickly? i.e. a few seconds before you come to a stop? or do you run through all the gears at the same pace?
I never go into 1st on a downshift. 1st in my opinion is only to get the car moving, after that only 2nd gear unless i am at a dead crawl. Now there are a few occasions where maybe 1st might be helpful at an auto-x or something, but its not worth grinding the hell out of my gears and burning the clutch up. Even then the time gained by downshifting is usually offset by the time taken to execute said shift.
I hardly ever downshift coming up to a stop light unless i know its about to turn green and i need to slow down a little. Otherwise i will let it come down to a bout 2k then shift into neutral, regardless of gear. No need to engine brake in my opinion.. let the brakes do the stopping. And, yes i rev match every downshift. I cringe when someone slips the clutch out
Also if it sounds like its right infront of you, it could be torque tube bearings (as mentioned), throwout bearing and possibly pilot bearing.
it would probably be best to have a mechanic check the pilot bearing and such before you ship a whole different transmission. Can that be checked without removing a bunch of parts?
yeah i figured that. That's how i always been taught. I never owned an automatic and i've been driving for 17 years. I've seen a few that do not shift like that so i was a bit curious.
$3400 for an axle would have to be something truly amazing
axle was free, life time warranty
