gap in seal - rear hatch
quick Q:
my rear hatch seal has a gap in it of about 1"
this is just above the lock mechanism
when viewed from the inside looking out, i can see the outside
i'm wondering, has the rear hatch seal 'dried up' creating the gap or is there something missing? (maybe a spacer or grommet?)
looks like this:
|---gap
hatch |
body O <--- lock
NOTE: it appears as if someone may have tried to break into the car as the hatch lock mechism is now hosed up (pressed in and won't spring back out)
thx
-rd
looks like this:
|---gap
hatch |
body O <--- lock
thx
-rd
oh man, my little ascii graphic got messed up when posting....
the lock should appear exactly below the gap in the seal
it's an 88 turbo...not that it should matter
the hatch pins are height adjustable - careful to make sure you loosen jam nut and if stubborn - gingerly work back and forth with penetrating oil to get them moving.
If you break off the pins you will officially have a bad day![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
good luck
good luck
not lock mechanism - the actual hatch pins (located on the hatch itself, go down inside the latches in the body of the car) They are threaded into the hatch thereby making them adjustable
Official Rennlist
Borat Impersonator
Borat Impersonator
The gap in the seal happens over time.... pull the old seal of and reapply it or you can do what I did and cut a little piece of an old seal and slide it in....but you would need a parts car for that....
My car is the same way. The seal in front of the little U hook that holds the rear hatch down is missing. I figured it just got ripped off and I would fix it when I get a new seal.
-GuyKeefer
-GuyKeefer
ok, so a new seal is in order
somethin's funky w/ the rear lock mechanism (not working)
i'll be climbing into the back, pullin the carpet and taking it apart...can't get the hatch to open at the moment (so i'll try manually pulling the 2 rods together at the center)
thx 4 the help all
thx 4 the help all
<maxwell smart> aaahhh the old microswitch in the rear hatch motor/lock mechanism trick, eh? </maxwell smart>
thx, 'preciate that ...will take a look
