My car emits this high pitched frequency at low throttle that seems to be coming from the fuse/relay box. I can hear it just outside the driver's side window in front of the windshield. It is kind of hard to explain but their is a part at low throttle where the pitch goes low when I press the throttle and goes high when I let go. I can't hear it unless it is changing pitch. It is an '86 stock in good condition. Any ideas???
Sounds to me like its maybe the valve for the EVAP system is having an issue?? It's right in front of the fuse panel and has vac. lines running to it. Other than that, it's not a speaker noise increasing with rpms is it? What about the buzzer relay in the fuse box? Pull it and see if the noise is still there.
