I'm done, make me an offer...
#168
Basic Sponsor
Monkeys Removed by Request
Strangly enough I had the same cylinder scoring in my that cause a burnt valve in my then brand new lindsey stage 1 head. I guess even though you can't hear it its there.
My temps were all completely normal just like RKD's. Pulled the head off and there is a hole through one of the valves.
#172
No. Dteonation was probably caused by missued pistons. If Chris is right, these pistons would have made the compression 9.0 to 1 rather than the intended 8.5 to 1. So, what MAY have been safe boost, in an 8.5 to 1 engine, MAy have been too much in a 9.0 to 1 engine. Piston slap happens when the engine is cold.
#173
Basic Sponsor
#174
See, here's the deal.
The reason (other than a new turbo and elctronics) that people don't just go straight from a 2.5 to a 3.0Ltr ( guys like me...looking at a 2.7) is that you can use wet or dry sleeves, in a 2.5 block, with the stock crank and new pistons...and there you have a have 2.7 or 2.8. <(106 mm sleeves like David Floyd)
The expensive part is that for a 3.0, you also need an 88mm crank,($) from a 3.0 block, or a full 3.0 block and crank, ($) then you need head work to make the 2.5 head match up ($) Or a 2.7 ltr head ($) then either sleeves and pistons, or Mahle pistons to fit stock bore (which cost more than sleeves and pistons).
So, from a 2.5 ltr block, you have to address the rod length and pin position. So from a 2.5 block, you need rods, BUT you already have the crank!
So you can have Chris wet sleeve (104mm) and piston (104mm from wossner, JE and some others) the 2.5 block, with the 88mm crank, and you have your 3.0ltr. deleted sentence
Either way, if you have a 2.5 block, I personally wouldn't want to sleeve it to anything over 104mm.
You, for close to the same money, have a useable 2.5 block to sleeve at 104mm. If you HAVE to sleeve, and I think you do, Why not sleeve to the safe maximum of 104mm? The price is the same for 101mm as they are for 104 mm.
Once you sleeve, you'll have to get pistons to match the new bore. You may as well get 104mm pistons. The cost difference, if ANY, is really small.
Add your existing, knife edged 88 mm crank.
you have you 3.0!
If I already had a crank, that's what I'd do.
For me, that's about 1000 to 1500 extra dollars. Then I still have to buy sleeves and pistons, get the haed modified to flow as much as you can, and your basically done. You should have a good set of Porsche con rods, from a donor car, or some custom rods from RKD's engine.
You'll need a turbo and some brains to run it on. You're done.
For those of us who have to sleeve, it's ALL about the crank!
I'm really exhausted, but did that make sense?
#175
actually, i chose not to go to 3.0 because of the increased piston speed and additional stress (and decreased longevity!) that puts on all related components, as well as decreased redline ability, lack of easily obtainable/replaceable parts, increased complexity for not too much gain, etc.
good explanation of what all is involved though, ehall.
#176
He's Lart... he can get a 2.5 block really cheap compared to the cost of sleeving plus he already has the head for the 2.5 block. He also has a 3.0l block from the S2 if he wanted to go that way but would need to do something about the head.
So, the cheapest solution would be a 2.5 block and pistons... or a 3.0l block with pistons and head work.
Karl at Racer's Edge is doing Wossner pistons for a really good price - maybe you should call him Lart.
#177
#178
Basic Sponsor
#179
C'mon tocayo, you're getting some good advice from people like George and Chris in this thread. Make it happen!
#180
I tracked his posts back and it was Lindsey racing that built his motor, another shoe-maker. I've had the same problem with these mechanics, Body motion, Paul miller porsche, they all are lousy mechanics. If I want the work done incorrectly I'll do it myself, you bring it to a shop and pay the big bucks to have it done right period. I would have brought the motor back.
