Safe to run Methanol inj @ 15PSI?
I know some Subaru guys running 35psi just with the methanol. I think the whole purpose of running methanol is reducing detonation, hens the term “chemical intercooling”.
I’m in the process of doing some homework on this subject, and every one I’ve talked to is raving about it. I’m most defiantly going with a meth system.
look at this kit http://www.snowperformance.net/products.php?p_cat=283
changing to E-85 will probably give u the same results. just more consistently. take the$1k. buy management run e-85. better deal all the way around. cheaper per gal. also.
Lazer Beam Shooter
the thing about methanol injection that is not safe is that it could run out of methanol or stop working for some reason. If this happens and you were relying on it you will get catastophic detonation. Methanol is better if you use it with, and tied into, a high boost turbo system when you add the extra PSI of boost for a short period of time it adds the methanol injection at the same time. If you are relying on it every time you go WOT throttle with a supercharged system you are running a fairly serious risk.
I had the snow performance meth injection on my old 327 ci supercharged mustang putting out 610 hp/589 tq. it was triggered by a unit tied into the maf sensor, port was just before the t-body, and it had a led panel to show when it was active and when the meth level was low. I used a 50/50 water mix with washer fluid. I also ran a lot of timing under boost also, no deonation, But then again it used a stand alone engine management with some really good tunes on it. never blew a head gasket. (used cometics)
when I up the boost and start modding mine I will definatly use the snow performance kit again. Besides the overall octane rating of about 130 when used it also cools the intake air charge also.
Semper fi.
Semper fi.
Snow Performances kit isn't the best but atleast the pump looks decent. However, its safety isn't up to par a quick look at the fittings/lines/tank makes me wonder if the kit was ever made for meth at all as it simply isn't safe to do things the way they are doing them in there kits.
Also, ontop of everything else remember that alkycontrols is horrible.
The Impaler
Basically the only performance that it offers is the ability to run more boost/timing. It's not nitrous.
Spencer - just run the car totally on E85 - there is already one station down below the 8 on the 15, and there will be three more in 2008. 108 or so octane, no detonation at all to speak of, cooler combustion temps, and its cheaper. You have to richen the mixture to 6 or 8:1, and run more timing, but that wil get you way more power since you can run much higher boost. If 15 is "safe" then think more like 25.
I can tell you that the snow kit is probally the best water/meth kit on the market. the plumbing is fine, it is no different then some of the plumbing used on even the 996 and 997 turbo, gt2's and gt3's. the push to lock plumbing is used for the p.s., and brake booster vacum supply's on newer porsches with no problems. the meth kit is not under high pressure, it is more volume delivery. you do not have to use the supplied resvoir (I agree it is on the cheap side) I would plumb the supply line to the windshield washer resvoir along with the level sensor for a much higher capacity. You do have to maintain the fluid level, and no it will not supply extra power like NOS, but it is a very good intercooler option that will allow you to run more timing and boost to make more power. I would use a multiple chip for diiferent tunes with and without meth tunes. I ran a system on the mustang called tweecer it was user programmable and it had 5 position switch for 5 different tunes that I was able to change on the fly. I also had no problems with the electronics of the kit.
Semper fi.
Rainman
i should replace all my fuel lines soon anyways, any recommendations to something that could handle both regular gas and possibly ethanol?
i have 4 extra CME's so i could just set one up to run the ethanol and swap them depending on my mood...lol
Semper fi.
Semper fi.
What makes snowperformace the best? from what I've read It's a very basic set up with little protection against failure.
I have a friend that runs aquamist and it is far superior to anything I've seen on the market. they have some really cool stuff.
http://www.aquamist.co.uk/cp/cp.html
Methanol injection will offer 0 performance gains other than cooler intake charge, cooler in cylinder temps (if you are mixing it with water) and it will be SLIGHTLY chemically richer.
Remember, Nitrous in itself does nothing, it isn't a fuel source at all.. It merely breaks down to 2 parts of oxygen, and mixes with the fuel that also had to be sprayed in with it.
Then again, merely looking at your statement of 0 performance gains, is like saying that you don't notice any difference at all in the performance of you turbo car when you drive it in 30 degree temps as opposed to 100 degree temps.
Lets see a show of hands, who has felt the performance difference in their turbocharged cars when the weather turns cold?
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
The Impaler
Actually.... The alcohol itself has a faster evaporation rate than water, which would allow it to pull the heat out faster than water. It is combustible, so you are adding more fuel to the mix which allows you to add more air(boost).
Lets see a show of hands, who has felt the performance difference in their turbocharged cars when the weather turns cold?![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
EDIT: and just because alchohol evaporates at a lower temp than water does not mean it cools better. Water has a higher evap temp but it dispells more energy when it evaporates.
My .02. You'll need to adjust A/F and possibly timing as well as running methonal injection when you raise the boost pressure significantly.
