fire sleeve for fuel lines
Old 07-19-2008, 06:00 AM
  #46
ehall
ehall's Avatar
Originally Posted by Brian Broderick
I did, see post #13
oops, wasn'tpaying attention to that.
Old 07-19-2008, 12:36 PM
  #47
nize
nize's Avatar
i still have some left over if anyone needs it. it takes a while to go through 50 feet.
Old 07-19-2008, 09:00 PM
  #48
ehall
ehall's Avatar
I'll let you know once I have the new car, and get to digging around in it.
Old 05-09-2009, 03:01 AM
  #49
sebastian944
sebastian944's Avatar
bump, interesting thread here... i want some of that fire sleeving...
Old 05-09-2009, 05:05 AM
  #50
PEvans
PEvans's Avatar
Isn't a leak of the fuel rail itself much more common than a failure of the line? When my 951 burned down I always figured it was the rail, and I have seen other posts to that effect.
Old 05-09-2009, 11:01 AM
  #51
reno808
reno808's Avatar
no. its the line
Old 05-09-2009, 11:08 AM
  #52
Duke
Duke's Avatar
The fuel rails are also a source of failure.
Old 05-09-2009, 11:10 AM
  #53
reno808
reno808's Avatar
more line and rails
Old 05-09-2009, 11:58 AM
  #54
sebastian944
This is a Porsche recall isn't it? What did Porsche do to correct this issue?
Old 05-09-2009, 01:43 PM
  #55
evil 944t
evil 944t's Avatar
I think thats when they decided to stop making 944 turbos
Old 05-10-2009, 02:27 PM
  #56
CurtP
CurtP's Avatar
What fails on the fuel rail (other than the jumper line)?
As for the fuel/return lines, I just routed them so they no longer sit over the exhaust. I ordered them from Rennbay with longer hoses (3' for the supply, 2' for the return IIRC).
Old 05-10-2009, 04:09 PM
  #57
V2Rocket
Rainman
V2Rocket's Avatar
is the rubber portion of the fuel lines simple enough to replace or does it take some serious disassembly? im imagining it to be a standard collar nut and thread onto the hard line.
Old 05-11-2009, 06:12 AM
  #58
ehall
ehall's Avatar
This seems like a good question.
Other than a line failure, why would there be a problem with the rail?
Can it get clogged?
If so, how?
What am I missing?
As with all system components, there may well be something that I've missed, and I don't like missing.
Thanks.
Old 05-11-2009, 07:18 AM
  #59
Duke
Duke's Avatar
The stock rail is hard brazed. Sometimes they can weap a little.
Old 05-11-2009, 10:24 AM
  #60
Travis - sflraver
Travis - sflraver's Avatar
The rail itself sometimes cracks next to where the mount is brazed/welded on.
Quick Reply: fire sleeve for fuel lines
