turbocharger review - pauer tuning
Old 10-15-2007, 02:06 PM
  #166
nize
nize's Avatar
updated with j-boot cutout mod to improve flow.
i also have an extra lindsey j-boot adapter for sale. this is brand-new and includes the modified cutout as well as the j-boot! $100. pm me if interested.
Old 10-15-2007, 05:31 PM
  #167
marcoturbo
marcoturbo's Avatar
PM sent
Old 10-15-2007, 05:57 PM
  #168
sawood12
sawood12's Avatar
Nize, good to see that there are turbo's out there that can offer good boost levels over the majority of the rev range. Just noticed one of your earlier threads where you say you still have the stock AFM in there with the door pinned open. In the stock setup it is actually the AFM that is the biggest restriction in the intake system. Cant you somehow hollow out the AFM casing to remove that restriction? People i've spoken to with stock turbo's that have ditched the AFM and gone with SciVision MAF's have said they noticed improvement in the turbo spool up time due to the removal of the AFM restriction. Might be a pretty simple way of getting a little bit more out of your current setup.
Old 10-15-2007, 06:18 PM
  #169
nize
nize's Avatar
good suggestion. i've met and seen some track-only 951's that were running similar setups to what i have now, and they are making around 400whp with the stock afm in place, which was the original reason i kept mine in there.
i'm planning on removing all of that to dyno-test a filter-only attached directly to the turbo inlet and compare that with the afm plumbing dyno to see if it actually makes a difference soon. stay tuned.
Old 10-16-2007, 12:51 AM
  #170
JE_951
JE_951's Avatar
Ihave a filter you can use. Ill drop it off when I get the fire sleeve
Old 10-16-2007, 01:03 AM
  #171
hally
hally's Avatar
Great data, thanks for sharing nize
Pauertuning have been a first class vendor for me also, from pre-sales right through to the packaging, can't wait to be getting some air through my T04E again.
Old 10-24-2007, 05:26 PM
  #172
nize
nize's Avatar
vendor info updated for milledge and lindsey.
Old 10-25-2007, 10:47 AM
  #173
Josh B
Josh B's Avatar
Did I miss the dyno results or have you not made it over there yet?
Old 10-25-2007, 01:17 PM
  #174
nize
nize's Avatar
haven't had much time to tune lately. first run hit around 317whp, though.
Old 10-25-2007, 01:32 PM
  #175
Josh B
Josh B's Avatar
Hmm - so with tuning you might be able to up that to 350? That is with bigger injectors/MAF/3" exhaust/bigger turbo/aftermarket wastegate/chips?
Old 12-22-2007, 02:39 PM
  #176
nize
nize's Avatar
dyno is up! read the first post in this thread.
323whp/334wtq at 17psi on 92octane pump gas
full boost at 17psi achieved by 2900rpm !
there's room for improvement, too. just need a bit more tuning.
Old 12-22-2007, 03:33 PM
  #177
KuHL 951
Hey Man
KuHL 951's Avatar
Nize...I posted to your pelican thread showing the graph...am I reading it wrong? I see 10-11 psi at 2900 and 20 psi above 5K.
Old 12-22-2007, 03:37 PM
  #178
nize
nize's Avatar
Originally Posted by KuHL 951
Nize...I posted to your pelican thread showing the graph...am I reading it wrong? I se 1-11 psi at 2900 and 20 psi above 5K.
the dyno boost sensor is not as accurate as the one in the EMS, or maybe it's just too sensitive, which could explain why the curve also fluctuates even though my VDO boost gauge shows a steady 17psi to redline. i'll post a separate log from the EMS later.
also, that boost dropoff at 5200 does not register on the VDO nor on the EMS.
Old 12-22-2007, 03:41 PM
  #179
KuHL 951
Hey Man
KuHL 951's Avatar
Cool. Your Wolf 3D seems to be working very well for AFR. Were you getting any significant knock counts on the winter blend 92 oct. gas?
Old 12-22-2007, 03:45 PM
  #180
nize
nize's Avatar
no knock at all.
chevron brand gas.
Quick Reply: turbocharger review - pauer tuning
