Never brag about your true HP. Dedicated to the hard core 951 fans.
Old 11-27-2006, 12:49 PM
  #91
lart951
Basic Sponsor
lart951's Avatar
Originally Posted by RolexNJ
Well said. John may jump in on this thread if he feels there needs to be a deeper/technical clarification on his products.
Luis: As I said, when I got John's MAF and his chips, right out of the box, the A/F was dead on the money somewhere between 95-98%? That damn close. You use the SMT6 to help you tweak things or get it better. Case in point, Special Tool is "obsessed" with having his turbo spool up as fast as possible, with having the A/F as best as he can get it. We did this with my old car too.
You remember the line from Young Guns?
"I'll make you famous"
Old 11-27-2006, 12:50 PM
  #92
Duke
Duke's Avatar
Originally Posted by facboy
i must be incredibly thick. if on an AFM car, the DME has no way to detect the increased boost and resultant airflow, how is it possible that you can keep turning up the boost and the AFR will stay more or less spot-on, as a number of you have stated?
The question above was if the AFM were maxed out. If it's not, it will add more fuel along with more boost.
Haven't tried it full out, but my impressions are that it doesn't add enough fuel. (stock).
As I usually like to point out in these cases are, if the DME didn't use the AFM signal what would happend during boost buildup from zero boost? It would run crazy rich and bog.
Old 11-27-2006, 12:53 PM
  #93
RolexNJ
RolexNJ's Avatar
From Emilio Estivez! --->
Old 11-27-2006, 12:55 PM
  #94
lart951
Basic Sponsor
lart951's Avatar
Now, the question is which chips???
Old 11-27-2006, 01:02 PM
  #95
RolexNJ
RolexNJ's Avatar
I told you my experience already with Vitesse? And you've heard people talk about the MAX Chips too. Luis, you're not a newbie here try the "search" button? Are you that lost, do we need to get someone from the 928 forums to help you search?
----> Lart
Old 11-27-2006, 01:19 PM
  #96
lart951
Basic Sponsor
lart951's Avatar
----> Lart
NO, I mean which chip's maker would like to sponsor the lartmobile?
Old 11-27-2006, 01:21 PM
  #97
RolexNJ
RolexNJ's Avatar
Keep smoking that crack with Ali G in Da House--->
Old 11-27-2006, 01:25 PM
  #98
toddk911
Drive-by provocation guy
toddk911's Avatar
http://www.951max.com/
Quick Reply: Never brag about your true HP. Dedicated to the hard core 951 fans.
