MAXhpkit introduces 951MAX performance chips
#48
Originally Posted by Frank@Work
I got maxxed!
Took the car out for a ride and the difference (compared to the Guru chips) is amazing. Especially at the bottom end of the power band the car is running extremely better/smoother.
The AFR is very steady, but was a little on the rich side. Took me only ten minutes to get those adjusted (with a SplitSecond PSC1-003F).
Are you considering new chips for your 951??? Go for the 951MAX chips. I can't imagine that you will be disappointed!
The support is also very quick! I made a mistake resetting my piggyback to zero which resulted in the car not idling (I accidentely resetted the piggyback to a setting which caused the car to run extremely lean). After reporting my problem I received an answer within 10 minutes.
(my car: '87 951, LR MAF, LR 3" no cat, LR WG, 3Bar FPR, Delphi 65lb/hr, K26/6@15psi)
Those looking for better driveability off boost all I can say is try it. Dyno sheets from other members already proves what this chip is capable of.
#49
Cool Cas, It is great to see more people trying then on their cars.
I was waitting for your reponce, because I also have the Scivison MAF , And I wanted to see how it work.
Q: when you order the chips, did you specify it for a MAF sensor or for a the original sensor?
Regards,
AL
Regards,
AL
#51
Regards,
AL
Regards,
AL
#52
Temprarily Banned per IB
Well all I can say is...
But to be fair and honest, cas was a little concerned at first. I was doing a bunch of 55# chips when I sent his out and sent him the wrong chip! Pobody's nerfect...
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
#58
Does it come with the Chip?
It look pertty cool.
Regards,
AL
Regards,
AL
http://forums.951max.com/viewtopic.php?t=38
#59
One thing with Russell's great support. He is also willing to share ideas and talk about anything other than troubleshooting your issues. Nice guy.
Efren
