dragstrip
i went to the strip tonight for the first time. on my first run i did a 13.5 me second was 13.8 and my third was 13.6s. thats for the quarter mile. all with 165 km/h trap speed. what are some other times people have done.
power wise my car is fairly stock exept for a dual port and apexi controller.
sean
sean
My GTech RR times are 12.97 @ 118 mph / 191 kph.
This run was made for getting the 100-200 kph time so the start was very soft gear changes slow! (60 ft 2.3 sec.)
12.30's with a 2.2 and 2.3 60' with just a k-26 and europroducts chips I went 13.5's. A little wheelspin helps with spool but it can get out of control. I turned my 12 sec times with a MAP kit and 315DR's and a K-27.
Drive-by provocation guy
wow, stock turbo with dual port must get you full boost at like...idle???? ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I would guess by 2,400-2,500????? Unless CV is slowing that down.
i was running 15 psi, it does spool up quick but lacks in top end. that will be fixed though because i have a vitesse stage 3 sitting at my workshop.
I pulled a 10.6 on the g-tech. 2.1 60 ft.
High boost. 139 trap.
The big jump from 4th to 5th in my S2 box kills my trap speed.
I'll be under 10 ALL DAY LONG with slicks and a 951 5th gear cog.
And it is really just starting to pull at the 1/4
Ask the guy in the 996 TT that I left 10 bus lengths behind Saturday evening on 84 coming from Marcus Dairy......![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
944 school was in session.
I'm usually around Marcus every Sat. around 7:00 - snake huntin'.
Look for the carbon hood vent if you're feelin' lucky...........
Basic Sponsor
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Basic Sponsor
Originally Posted by 2bridges
UHhhhhhhh. Hey I'm not saying your full of it, but WOW! I would be very curious what gear you are running to need 5th in 1/4
what is your trap speed??
Basic Sponsor
I don't think I am buying what your selling....... but if true, I think I would have to see it myself, and then pay homage ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Do some reading.
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/233315-well-i-promised-you-guys-before-2006-vitesse-s3-with-sfr-headers-dyno.html
