Vitesse Turbo Cost
Can anybody tell me why the Vitesse Turbo itself (in this particular instance, the stage 3 turbo) costs $1900 all by itself??
I arrived at this price by deducting the price of an MAF + PB kit from the cost of the full stage 3 kit. ($3700-$1800=$1900) Even if it were something as nice as a Garrett GT30R (which would be capable of even more power at the given boost levels of 15-17psi) it should only cost ~$1200 or so...
I was just looking at the site with alot of curiosity for my upcoming 951 purchase which will go unmodded for all of a few hours...my family gives me all kinds of crap for typically buying modifications for a car before I even take ownership of the car.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Originally Posted by aeronautica86
the extra cost is to cover John's R&D as well as the custom modifications that he does to the turbos before he sends them out
Maybe im off base here...
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
well, businesses have to make money
also, take into account the cost/hp curve - it may only take $500 to get an extra 50hp (chips, gauge boost controller), but it'll take another ~$3500 to make another 50-60 hp on top of that (wastegate, exhaust, maf, injectors, small upgrade turbo like k26/8 or k27/6) - in other words, to get up into the higher regions of the possible horsepower range for a given car, it takes alot more money or put another way, it takes alot more money to squeeze out the last extra bit of performance. So basically you may be able to buy a dbb turbo that is well suited for the 951 for ~$1200 and it will perform quite nicely, but to get that little bit extra is going to significantly increase the price - so what do you want, good performance for $1200 or excellent performance for $1900? It just depends on whether or not that performance jump is worth it to you.
edit: yes, his maf kits include the needed software
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
For $100 I’ll sell you a true do it your self kit – a box of Iron ore and a chunk of aluminum. Think of the savings…
What you are paying for with John’s turbos is a product that works and is reliable. If you figure the time it takes to get a turbo out and back in it is not worth the effort to sort through a whole list of turbos that are supposed to be good. I have tried a number of combinations and some were pretty decent – they gave good power output but at the expense of low end performance. John’s turbos have both bases covered - he spent the time, money and effort testing out different combination and modification and it shows.
You can get cheaper turbos – but none that were custom made for 944s. After the third ‘cheap’ turbo you will wonder why you didn’t get the right one to begin with!
Chris White
Chris White
I have many toys, so someone has to pay!!
LOL..
The VR turbos are not something you get off of the shelf. Some of the components were not designed to be packaged in a way to fit the 951. As an example S3 turbo makes 1bar boost in the 3200-3400rpm, yet is capable of supporting 500+rwhp. The fast spooling and the performance capabilities take lots of work to achieve. Not to mention the work we do for the internals...
I have seen others claim their turbos does the same, however in real life it just didn't happen.
For those that want an entry level turbo, we offer it as well. $1250 for a entry level turbo, just don't expect all the extras you get with the VR turbos...
As I responded to Chris White, I am a firm believer in avoiding DIY setups when there is a proven kit available, i was just perusing your site (which could DESPERATELY use an update.
Thanks.
I've seen decent 951s for less than the price of an installed kit ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Yes its true that each additional HP after say 50hp gets increasingly more expensive than the
previous one.
previous one.
If you catch me on a good day, I might even throw in the injectors.. We run specials every now and then where we give you free injectors ($350-400) for free with the kit.
It's a no big deal to be a turbo reseller, get wholesale, mark it up and let it go. If you want "ok" products, the market is full of them. If you want a product that works as advertised, you have to do your homework.
This is not just for turbo selection... it applies to MAF, software....
I was just looking at the site with alot of curiosity for my upcoming 951 purchase which will go unmodded for all of a few hours...my family gives me all kinds of crap for typically buying modifications for a car before I even take ownership of the car.![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
There are MANY hours of custom machining and all units are blueprinted.
The turbo in my car is a stock, off the shelf Vitesse stage 3. I have some special stuff for it, but I have never used it. It makes 600+ horsepower (soon to be 600 at the wheels) and I have 1 bar boost by 3500 RPM with stage 2 headers and HUGE intake valves.
You can have the same turbo I use - just ask. It may be expensive, but it will renew your fear of God.
) and started to wonder about the pricing.
Thanks.
Thanks.
I'll second that
