Rebirth of a racecar - project pics
#48
Looks great Skip! Is this being built to any particular race series specs, or just to be used for DE's and open track days? I'm curious, with the CF body panels, what this will weigh when complete. Any idea? And are you using lexan for the front and rear windows?
#50
I am planning to run it in the NASA GTS series as well as DE's. I'm curious about the weight as well. It has a glass windshield and rear quarter windows and will have a lexan rear window (Mike has the original one). At the 2450 mark it had fiberglass doors - has steel now. It also had the Kokeln rear torsion bar sub assembly which Mike now has. However it had a modified stock dash and it now has the GT Racing CF dash. I believe it had a CF front front bumper cover and I believe that has been replaced with a fiberglass unit. It also had the full headlight assembly - lights, motor, linkage, etc., and that is all gone. So some stuff has been added and other stuff has been deleted so we'll have to see how it ends up.
#51
I am not real familiar with the NASA series. If you don't mind my asking, what made you choose NASA over other series, such as PCA Club Racing? Feel free to PM if you want, I don't mean to hijack your build thread.
#54
Took advantage of my holiday vacation to pull the motor from my parts car. Brant Giere, a local Rennlister, has a nice mid-rise scissor lift in his shop, which made life easier, and Tom Leigh, another local Rennlister, came over to help wrench. Took us about 6 hours with a short break for lunch. The last hour was spent removing little bits and pieces that were causing the motor to hang up, and figuring out that the input shaft is damn long. I trailered the motor back to my house, got it in the garage and will start prepping it to go into the Technodyne car this week.
#55
Awesome! Yeah, that input shaft is a PITA. Unless the transaxle is out, then you can just kick it back out of the way. (I hope I mentioned that before you went to do this!) Look forward to seeing more progress You're doing better than me now.
#58
Thanks Dan. I'm a bit of the fence about how far to tear down the motor. The motor was rebuilt about 2k miles ago (verified by Scott Harrisson) and so I hate to pull the head to verify - seems like a waste of time and money, however it will never be easier now that it is off the car - wish I had a borescope. I have a handful of things to do before installing it and beginning the dreaded wiring.
- Remove the stock wiring harness and install the TEC3 harness.
- Install crank trigger assembly for the TEC3.
- Pull the AC compressor and install an AC delete kit.
- Delete the heater valve and hook up a bypass hose
- Redo the vacuum lines to eliminate the emissions equipment
- Install Lindsey fuel rail
- Install Lindsey 2 piece crossover
- Identify turbo
Probably the biggest issue is to identify the turbo. It is supposed to be a ceramic coated, ball bearing Garret but that is all I know. It is in fact ceramic coated and the cold side has a serial number plate on it. I'm fairly ignorant when it come to the various turbos, but in talking to Magown, it looks like I will most likely need to pull the turbo and open it up so I can measure the wheels. Once I know what it is, then I ca decide whether to use it, a k27/6 7200 sitting in my garage , or I could sell both turbos and go with a Lindsey Super series which I am considering - known entity and I could eliminate a lot of the turbo coolant lines which really opens up the front/side of the engine bay.
- Identify turbo
#59
Originally Posted by black944 turbo
Skip, you selling the suspension on the car? Please PM me if you are. Are they bilsteins or Konis? Good work on the car.
#60
Skip, I like option number 3 for your turbo choices. After selling both turbos you'll easily have enough for a new turbo. That way it's new and you'll know what it is. I'm also a big fan of eliminating all the turbo cooling parts. Makes the engine bay a lot less of a mess.
I have a factory ac delete bracket for sale if you need one.
