Time to present the "GO BIG.."-project! With pics
Old 12-22-2005, 07:23 PM
  #31
porshhhh951
Monkeys Removed by Request
porshhhh951's Avatar
Originally Posted by Duke
Indeed! Me and a good friend (and co-builder of the car) were just looking at your pics and said to ourselves "THAT's how our exhaust should look like when it's finished"
Gotta love the polished SS 4" Magnaflow, we'll be using that one as well
deffenetly a good way to go.
My entire SS exhaust spent like 5-6 days at the polisher. Those pics really dont do it justice...it literally looks like jewlery.
goodluck with your project buddy...its going to be a screamer
Old 12-22-2005, 07:40 PM
  #32
shortyboy
shortyboy's Avatar
what cleaner did you use for your parts and block?
Old 12-22-2005, 07:49 PM
  #33
Duke
Duke's Avatar
I used a good friend and partner for that, I highly recommend going that route
I'll ask him to chime in about the cleaning process.
Old 12-22-2005, 08:06 PM
  #34
ehall
ehall's Avatar
Way to go Duke. Good luck. This will be fun to watch progress.
Old 12-22-2005, 08:30 PM
  #35
shortyboy
shortyboy's Avatar
btw,i have a similar set of bushings but i dont know what brand they are,what brand are you bushings?
Old 12-22-2005, 09:57 PM
  #36
Skunk Workz
Skunk Workz's Avatar
Originally Posted by David Floyd
I smell some power ! I wanna see the intercooler.
Black Project...all info that is hinted to is that it might be a high-flow, pure bolt-in IC with NO cutting of the car needed.
Old 12-22-2005, 10:01 PM
  #37
Skunk Workz
Originally Posted by Black Arrow
Looking forward to your project Bjørn and Duke!
I KNOW this is gonna be one h*ll of a engine!
Hmmm...why is that..?
Old 12-22-2005, 11:13 PM
  #38
porshaowner
porshaowner's Avatar
Originally Posted by 944CS
I wouldn't delete the balance shafts...you will only put more stress on your engine and more wear on it also....did you ever take the balance shaft belt off and drive the car? After spending all that money on making everything top notch, you will end up with an engine that shakes the whole car and a car that is annoying to drive.
tech. reference - http://www.dinancars.com/whitepapersFile.asp?ID=5
Dinan's cars come with factory warranties and are sold through BMW dealerships.
944cs, your confused. A harmonic balance shaft is not the same as a crankshaft harmonic damper. There is a good chance that the engine will not shake just by removing the balance shaft belt, but if the shafts are out of time with the belt installed it will create a major vibration that will destroy things.
Old 12-23-2005, 02:10 AM
  #39
Laust Pedersen
Laust Pedersen's Avatar
Me too... A hint is that we're planning some serious boost for this engine.
I like that, finally somebody who admits their "boostaholic” tendencies and follows through.
Very interesting and inspiring project and nice pictures too; I look forward to the next installment.
On the balancing discussion:
A harmonic balancer/dampener counters the torsional oscillation of the crankshaft as described by Dinan in the referenced article. However its main balancing mechanism is an out of phase oscillation at the same frequency as the crankshaft’s first torsional harmonic (fundamental frequency), beating against the peaks of the crankshaft’s oscillation. As mentioned the rubber mount also has some internal energy absorbing properties, which can make it heat up. This also means that a harmonic balancer is designed to a specific crankshaft and is unlikely to work as intended on a modified (changed moment of inertia and stiffness) or different crankshaft. In the worst case (synchronous oscillation) it might do more harm.
The balance shafts counters (but not fully) the fact that pistons (pairs) pass the TDC faster than the BDC and therefore give an upward jerk to the engine each time a piston pair passes the top. This cannot be balanced out by other means, except by using infinitely long connecting rods.
Has anybody documented the HP gain obtained by deleting the balance shafts?
Laust
Old 12-23-2005, 03:54 AM
  #40
944CS
944CS's Avatar
their job is the same, the link was just to give insight on what goes on in an engine. i have taken the balance shaft belt off and run a 944 engine for a short time, and it shook the whole car.
and i remember a post by john anderson, who dynoed a N/A 944 and gained...........wait for it.........2.5 hp
Old 12-23-2005, 04:09 AM
  #41
DDP
Rocket Scientist
DDP's Avatar
Laust, are you saying it is ideal to get a correctly matched harmonic balancer to a knife edged crank? Also that if you knife edge the crank it has nothing to do with the balance shafts because the b/s balance out the pistons and not the crank?
Old 12-23-2005, 04:38 AM
  #42
Olli Snellman
Olli Snellman's Avatar
Not you average Walmart bolts (or Biltema as we say in Sweden)
Ikea is for the Ladies, Biltema is ours
Somehow your enginestand looks familiar....
Here's mine
Nice job Gustaf, hope i can see all that "stuff" when i come over to Stockholm in January (will send my wife to do some shopping for example at Åhlens )
Let's see what we can do concerning that 968 wing...
I used this:
Old 12-23-2005, 05:35 AM
  #43
freddie_fish
freddie_fish's Avatar
Greetings everybody!
The name is Fredrik and I am building "The Green Hunter" together with Duke in the Revline Racing garage. (We also built The black Revline Racing track car last winter) Very excited about the upcoming work and we will for sure post loads of info for you!
I noticed a question about our cleaningprocess and tought i´d post a quickie regarding that.
First we put all loose parts into a bath of pure diesel for atlest 4-7 days
Then we prime with Hot Shot, Bräkleen from CRC or similar (here is also where we started the work on the big parts that dont fit into a bath.)
After this we use compressed air in a blend with pure diesel to spray down the parts, during this we also use a regular brush to by hand scrub the whole thing.
The last two steps contains a degreaser (a kind of soap) with water and after that pure water and a regular cloth to dry everything.
It takes a while but the results are worth it!
Cheers mates!
Old 12-23-2005, 05:50 AM
  #44
Duke
Duke's Avatar
Weltmeister. They have both brand and part numbers casted in the sides.
I just need to get hold of a good teflon grease now to minimize the squeeking.
Old 12-23-2005, 05:58 AM
  #45
Duke
Duke's Avatar
I know you're quite a boostaholic yourself Laust and I don't think you will be dissapointed
Quick Reply: Time to present the "GO BIG.."-project! With pics
