vitesse CA legal?
Read the legal document on the web site. Most if not all of the products are for off-road or racing purposes. Never any claim regarding emission certification..
The kits are designed to run clean and many customers passed smog tests. Check your area for legality of the parts.. Again, the kits are for off-road or race use only!
As far as the visual goes, keep in mind that the smog book states that "an electrostatic airbox is not required" for the 944 Turbo. I've passed with a K&N filter and my Guru MAP kit, but it's a bit more stealthy than a MAF setup. I think you would be able to easily pass a visual by using the MAF and routing it through the stock airbox. There's even one Rennlister on here that made his own stickers to make it look like a factory part. :-)
A typical MAF with cone filter will not pass visual, unless you get lucky or unless you work to make it look fairly stock. As long as the car stays in closed loop during the test (all light load), the actual emmissions should not be a problem.
Originally Posted by Mike S
Vitesse....how about developing a "stealth kit" that plugs your MAF into the stock airbox to draw as little attention as possible.
Its the proverbial round peg in a square hole
Not really. Guru did the same thing with a 3" pipe to stock airbox intake. You have to bore out the stock airbox hole a bit, but I've seen it done with a MAP kit and a local guy (Bill) who did it with a MAF. Essentially, you would just turn the bend in the pipe the other way and use an adapter to mate to the airbox.
Defending the Border
Rest In Peace
Rest In Peace
How about a couple of pics, this is an excellent idea!
Did you use the stock snorkel into the fender well? Can the stock snorkel handle the CFM of a MAF? It gets around sucking hot engine bay air.
A simple solution:
- Order the Vitesse software with an additional image to support your injectors/FPR and AFM.
- Install the AFM for testing, fllip a switch on the VR chip/board to select the proper image (you keep the FPR and injectors as with the MAF).
- Once inspected, put the MAF back on, flip the switch to select the MAF image..
All of this will take a 1-2hrs which is acceptable to spend once year.
